12-05-2009, 11:12 AM | #1 |
what model front clip?
Anyone know if just the grill is changed or thew whole front clip on this truck? The man is telling me it is a 68 but the vin is coming back 72.
12-05-2009, 11:19 AM | #2 |
Re: what model front clip?
it has a 68 front clip on it for sure.. but i cant remember if power brakes came on a 68?
but if your vin is coming back a 72, then it is a 72
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333 |
12-05-2009, 11:23 AM | #3 |
Junior Member
It wasn't just the grill.
It could be the front clip. The cab may have been put on another frame. Does it have disc brakes? Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
12-05-2009, 11:25 AM | #4 |
I have not checked the breaks. Just looked at it yesterday a friend told me about it. It has very little rust and most of the body work is done. He is asking 500. I thought it sounded good. Even if I use some of the parts for my truck.
12-05-2009, 12:16 PM | #5 |
67/68 used a large horizontal handle to pull emergency brake, while 69/72 used a floor pedal. That may give you a clue of the cab has been changed.
The Master cylinder looks like it goes with a disk brake setup. Normally the drum/drum has the same size for both fluid reservoirs. What does the frame VIN say?
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-05-2009 at 12:18 PM. |
12-05-2009, 12:24 PM | #6 |
its all about the +6 inches
whats the VIN?
Has the VIN tag been tampered with? what does the title say (assuming you are getting one since it is not required there) does the VIN on the frame match the cab? If you posted some pics of the inside of the cab we could tell you pretty quick if the cab is a 68 or a 72, a photo of the VIN plate would tell a whole lot. |
12-05-2009, 12:35 PM | #7 |
Vin is CCE142A161639
12-05-2009, 12:57 PM | #8 |
From the pictures it is a later model (69-72) cab.
With all the other indicators, I'd say it is a 72 with a 68 front clip. The double CC starting the VIn tells me (as does the rest) that it is a 72 VIN#
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-05-2009 at 12:58 PM. |
12-05-2009, 01:04 PM | #9 |
The doors are not 72's.
I'm not as good as I once was, But I'm as good once as I ever was. |
12-05-2009, 01:08 PM | #10 |
Moderator
Based on the VIN, you have a 72 cab.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-05-2009, 02:30 PM | #11 |
Seem's a bit of a mystery to me. The steering shaft is 69-72. The e-brake pedal is 69-72, but the dash looks 67-68. I'm not sure, but I don't think 67-68 had power brake. If you buy it and tear it apart, another clue is the core support mounting holes (the bracket attached to frame) the 67-68 had a small hole for the rubber mount and the 69-72 a larger hole 1.14" vs. 1.67". This will at least tell you what year frame you have. Good luck !
12-05-2009, 02:45 PM | #12 |
there should be a vin on the frame on the drivers side ahead of the cab i believe. the dash looks like 69-72(just 2 holes compared to a possible 4). I would lean towards a pieced together pickup, but check the vin on the frame(it'll tell you if it matches the cab).
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
12-05-2009, 02:46 PM | #13 |
it looks like it may have a truck tilt. That, if its in good shape could fetch 300. You can also look under the seat at the flat middle section of the floor( under the seat). If it has some stamps in it and its not flat there, its 67 or 68 cab.Looks like 67-71 doors, 68 clip, 72 cab poss. Check the vin tag . Is it put on with regular rivets or flower shaped ones?
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
12-05-2009, 04:13 PM | #14 |
Burnouts are therapeutic
looks like a 72 cab swap, but at that price I wouldn't hesitate to buy,deffinently $500 worth of parts there.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
12-05-2009, 04:39 PM | #15 |
ok here is my 2 cents the gauge cluster is a possible 72 cluster cause my fathers 72 is the same and he got his from the factory like that then the booster my brothers 68 came with a booster in his longbed truck and the spid on the glove box all say that
12-05-2009, 06:32 PM | #16 |
Car Knocker
Cab been drilled for a rear view mirror, or does it look like it was attached to the windsheild? My vote is a reclipped 72 model. Still I would buy it just for the parts.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
12-05-2009, 06:38 PM | #17 |
like BigMike said, the doors are not 72's, (no screw below vent windows), but the door panels sitting on the floor are 72's. Only year with those plastic formed units.
12-05-2009, 10:30 PM | #18 |
Look at the support brackets for the booster, that's 71-72 only. Must be a 71-72 cab with 68 front clip.
12-05-2009, 10:39 PM | #19 |
Better check and see how much of that bondo is gone
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thread Tools | |
Display Modes | |
