Old 12-11-2009, 04:14 PM   #1
sdime95
Question new motor not running right
ok so i decided to have my 260,000 mile 305 replaced with a new 305 and it idles fine but you give it a little gas in park neutral or drive and it studders like its running out of gas but one your going it runs fine in all gears and speeds my truck is a 87 silverado auto 2wd w/ new 305 any ideas on what it could be cause i have had my truck in the shop for a month now and am starting to get fed up of mot have my truck and it not runing right thanks in advance
1984 Sierra 1/2 ton 4x4 swb
1987 Silverado 2wd swb 3/4 drop
sdime95 is offline   Reply With Quote
Old 12-11-2009, 06:22 PM   #2
J_PEPIN87
J_PEPIN87's Avatar
Re: new motor not running right
Have you checked the timing
J_PEPIN87 is offline   Reply With Quote
Old 12-11-2009, 06:38 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I got a nickle that says the plug wires are on wrong!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-12-2009, 04:07 AM   #4
Kixwy2
Kixwy2's Avatar
Is it a stumble off idle? I've had that... you may have to adjust the carb to fix that.
1974 GMC C-10; my new addiction
1998 4 Runner; daily driver
Kixwy2 is offline   Reply With Quote
Old 12-12-2009, 10:53 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Put a vacuum gauge on it. It should be pulling close to 24 inches in a stock mid 80's 305 like my 83 did. You could have a big vacuum leak.
Next check to make sure the timing is right and all the plug wires are in the right order. Its easy to get two crossed over.
Then check to make sure you don't have a fuel delivery problem. Make sure it has fuel pressure at the carb and full fuel bowls. It could be a lean stumble off idle caused by not enough fuel volume or pressure getting to the carb.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-12-2009, 11:52 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
stupid question its got a new gas filter ? id also check that and make sure its ok in addition to what the others suggested
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-12-2009, 05:02 PM   #7
sdime95
sorry i didn't say it's a TBI not carb. fuel filter is new, timing is good, new o2 sensor. still feels like its spuddering but now it doesnt do it all the time only on occasion aghhhhhh!
Old 12-12-2009, 05:40 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Question Re: new motor not running right
You say the timing is good but did you set the base timing with the EST disconnected ?
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 12-12-2009, 06:55 PM   #9
3r!c84
Badass
3r!c84's Avatar
i got a dumb question.why did you get a 305? why didnt you upgrade to a 350?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-14-2009, 12:32 PM   #10
68 TT
68 TT's Avatar
That makes things a little different. Since it is TBI you need to do a little work to get a fuel pressure gauge on it but you need to know what the fuel pressure is to make sure you have enough. 10 pounds or under and you would be lucky if it ran at all. Shoot for 13 to 15 psi.
You still need to make sure the basics are good (vacuum, spark, plugs, wire routing, etc...) but you should also get an ALDL connector cable to data log what your ECM sees. It will help you out tremendously. thirdgen.org is packed full of info on getting started with data logging.
Old 12-14-2009, 10:51 PM   #11
sdime95
thanks im taking it in tomorrow to the guy who put it in i will make sure to have him check these things any other ideas would be great
Thread Tools
Display Modes
