12-12-2009, 10:56 AM | #1 |
Swapping 6 lug rear on a 85
Im looking to convert my 85 to 6lug. I already have the front end taken care of thanks to early classic. For the rear I have come across a 6 lug rear with dics that has already been narrowed 4.5" per side. I plan on running a 24"x10" wheel with either a +12 or +32 offset. I know the 6 lug rear before being cut is alittle wider than the 80's model rear. Im just worried that the 6 lug rear being cut 4.5" per side might be a little to narrow even with running a 24"x10". Anyone have some exsperience with this situation, or know how much wider the 6 lug rear is than the 80's model rear? Any info would be a help.
12-12-2009, 11:20 AM | #2 |
67-72 parts collector,…
Re: Swapping 6 lug rear on a 85
Can't you just measure the differnce between the "narrowed" 6-lug rearend and your stock 5-lug rearend? (total width)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-12-2009 at 11:20 AM. |
12-12-2009, 11:31 AM | #3 |
ya i could but the guy who has the 6 lug rear is out of town for a few days so he isnt around to give me the lengh measurments so i figured i just ask
12-12-2009, 12:08 PM | #4 |
Happy to be here
What year is the 6 lug rear?
12-12-2009, 01:32 PM | #5 |
Pull the axle shafts from a 4x4 10 bolt rear and stick them in your housing. Six lug, cheap.
I can still count my vehicles on two... wait three hands. |
12-12-2009, 02:39 PM | #6 |
Ya nevermind the guy wants way to much for the rearend
12-12-2009, 02:41 PM | #7 |
12-13-2009, 03:13 AM | #8 |
At the body shop.
Get the drums too
" That didnt make it any newer " " Dont antique the equipment " |
12-13-2009, 11:05 AM | #9 |
Still plays with trucks
If the six lug axles are from a square body 8-1/2" 10-bolt they will fit with no issues.
The new body style trucks got a spline change in their 8-1/2's up to 30-spline and they are a little wider, plus the housing brackets are different. With what you want to run I would stick with the square body rear end.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-13-2009, 12:24 PM | #10 |
12-13-2009, 01:22 PM | #11 |
From info i found on the net the only difference i found between the 4x4 and 2wd axles is that the 4x4 axles is 31 5/16" in lengh and the 2wd is 31 3/8 in lengh. Thats only a 1/16 difference between the two axles.
12-13-2009, 07:55 PM | #12 |
bump
Thread Tools | |
Display Modes | |
