Old 05-22-2002, 04:58 PM   #1
tim m
Post Lift kit
Can anyone recomend a lift kit? I want to go with one that is a 4 inch. I have a K10, each 4 wheeler shop I have been to recomends a different brand.
Thanks Tim
1970 k10
1971 C10
Gilbert Az
tim m is offline   Reply With Quote
Old 05-22-2002, 05:01 PM   #2
ViperRed67
Post
I put a tuff country easy ride 4 inch on my 69 last year. Worked out ok and lifted me up a true 4 1/2 inches. The ride was better then stock as was the handling. I shopped around for the beat riding spring and that was the answer I came up with.
ViperRed67 is offline   Reply With Quote
Old 05-22-2002, 05:30 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
www.offroaddesign.com 4" ez ride tuff country front springs, shackle flip in back
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 05-22-2002, 06:47 PM   #4
Mike C
Mike C's Avatar
Post
Skyjacker 4" system with front and rear springs and drop steering arm. Stock springs are usually clapped out after 30 years. I have National 4" springs on the back of my truck with a 3/4 ton rating. It sits nice and level still and the lift is 13 years old. I bent the perches on my diff housing with 2 1/2" blocks and add-a-leaf I originally had. Never use blocks again. I have a 20' boat with 400# tongue weight and they handle it well. I have Rancho 4" fronts, a ProComp steering arm and shocks. I pieced mine together, but the Skyjacker system is a food deal for $550 or so. My rear springs were $300 by themselves in '89.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 05-22-2002, 06:52 PM   #5
jerry moss
Born Psycho
jerry moss's Avatar
Post
i like the ride of tuff country best, i've had two trucks with their 4 inch kits. i have another truck with a 6 inch skyjacker softride and it'll beat you to death. all trucks are longbed 3/4 tons.
jerry
72 cheyenne super K20
72 cheyenne K20
72 custom K20 - FOR SALE
79 K-5
90 SS454 PICKUP
BRENTWOOD,CALIFORNIA
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
jerry moss is offline   Reply With Quote
Old 05-23-2002, 02:17 AM   #6
Mudder
Mudder's Avatar
Post
hav had both the tuff country soft ride and heavy duty. 4" like the ride of the heavy duty better.
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 05-23-2002, 05:45 AM   #7
Pont
I need another Barley Pop
Pont's Avatar
Post
if money is of no concern, have the springs made from someone like National Spring in California. They charge $100/inch for the pair. 4" springs would run $400 for front or rear and they can make them ride however you want. I had to have them make me a pair of rears because nobody makes them for my 67.
67 SWB 4x4 - 396 BB / SM420 4 spd
8" lift / 15x14 Welds & 35X14.5 SSR's
Grants Pass, OR
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-23-2002, 08:29 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
I'm happy with my Tuff Country front springs and also like the shackle flip that 68SWB4x4 mentioned. Check out my website for more info on that setup and install. I would probably pick different shocks though. I have the Tuff Country SX8000's and I would like to change them out to the adjustable Rancho's. Your probably will want to get a steering stabilizer assuming your are moving up to some big meats.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-23-2002, 09:01 AM   #9
Beast388
Suburbans RULE!
Beast388's Avatar
Post
I have a Rough Country 4" Lift that I am fairly happy with. It is a little stiff but the weight of my Suburban helps. This kit used 4 springs not blocks.
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 05-23-2002, 08:53 PM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Post
Here's somethimg to read: http://www.truckworld.com/How-To-Tec...uspension.html .
1970 GMC K25 Custom
Chesapeake, VA
My 70 GMCor Webshots http://community.webshots.com/user/70gmc
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Thread Tools
Display Modes
