Old 12-14-2009, 07:10 PM   #1
T Hilde
1949 3600 build
Got this truck a week ago
T Hilde is offline   Reply With Quote
Old 12-14-2009, 07:13 PM   #2
T Hilde
Re: 1949 3600 build
This how the floor looked before I cleaned it out. There was a ton of nesting and rat crap under the seat.
Old 12-14-2009, 07:14 PM   #3
T Hilde
Re: 1949 3600 build
It is a very solid truck, a couple of rust spots. But look at the color from firewall.
Old 12-14-2009, 07:18 PM   #4
T Hilde
Re: 1949 3600 build
I plan to use the front & doors from my 3800, a 292 inline and a 5 speed.
Old 12-14-2009, 07:21 PM   #5
T Hilde
Re: 1949 3600 build
This is where is as of last night.
I am getting it ready for this cross member.
It takes the S10/G body suspension stuff and a rack&pinion.
Old 12-14-2009, 08:31 PM   #6
chevy49
chevy49's Avatar
Re: 1949 3600 build
where do you get this cross member?
chevy49 is offline   Reply With Quote
Old 12-14-2009, 08:57 PM   #7
T Hilde
Re: 1949 3600 build
It is from Scott Danforth. He is on the HAMB and Stovebolt.
Old 12-15-2009, 02:54 AM   #8
kulturekat
kulturekat's Avatar
Re: 1949 3600 build
man love this truck i have a 47 3600 so im glad to see more are popping up here. good luck with yours cant wait to see more progress. you got lucky on your insides shoulda seen mine haha
1969 c-10- daily driver(sold)
1950 chevy 3600 current project
http://67-72chevytrucks.com/vboard/s...d.php?t=402562
1955 ford f-100
1968 ford mustang
1966 ford mustang
kulturekat is offline   Reply With Quote
Old 12-18-2009, 03:18 AM   #9
T Hilde
Re: 1949 3600 build
Thursday: I met with the welder and got a good price. I will do all the fitment and he will just have to weld. He really liked the kit and thinks it will be easier than the Hiedt's front he did for another guy.
I got all the bracketry off the passenger side frame rail and sanded it down.
Between the red lines is really only needed for prep. I sanded inside the rail and underneath too.
The bell housing crossmember is in the way a little bit. It will be removed after the cross member is welded in. This is the part that is in the way.
Here it is removed from the other side.
A bracket needs to be welded inside the frame rail for support. Scott gives very detailed measurements of where it needs to be. After studying the install manual, I'll show you the dummy way. Again on the passenger frame rail, (right side is front) the red circle shows the hole the bracket needs to be placed over. The large hole is where the brake line came out.
Looking inside the rail, (left is front) the bend goes to the front.
Next, I will prep the other side. Then fit the boxing plates.
Old 12-18-2009, 09:29 PM   #10
Arkansas50's
Arkansas50's's Avatar
Re: 1949 3600 build
[QUOTE=T Hilde;3674856]This how the floor looked before I cleaned it out. There was a ton of nesting and rat crap under the seat.
I think the rat crap comes standard in these trucks. I have a friend that built a 3600 with MII front and drop spring rear with S10 axle. It looked pretty good and did'nt look like a lwb at first glance.
Arkansas50's is offline   Reply With Quote
Old 12-21-2009, 03:47 AM   #11
T Hilde
Re: 1949 3600 build
Sunday: Got more accomplished.
Started getting things roughed in. The front of the frame needs a little notch. It is measured from the front edge of the frame. At first I was how the hell?? But, here is how. Use a welding magnet and fish the tape through the frame.
Then your masking tape marks the notch.
Cut out.
My boxing plates ended up being a little long (which is way better than short). I set them up in the frame located where they should end, then set up for a 3 inch hole. (forgot to grab camera)
Then made finishing cut on the bandsaw.
Test fit with my son the hand model. I wonder what he thinks of this?
For the hell of it we slid the crossmember up there.
Next up is more grinding, fitting and getting the welder to come in.
Old 12-21-2009, 08:15 AM   #12
junkman1jmc
junkman1jmc's Avatar
Re: 1949 3600 build
you gonna leave it a long bed .
junkman1jmc is offline   Reply With Quote
Old 12-21-2009, 03:08 PM   #13
T Hilde
Re: 1949 3600 build
Yes, but I do want to remove the stake pocket from in front of the fender.
Old 12-21-2009, 04:05 PM   #14
1952ssr
1952ssr's Avatar
Re: 1949 3600 build
Looks good, better than I expected. I tried finding a price for that kit but, no luck. How much did it set you back.
1952ssr is offline   Reply With Quote
Old 12-21-2009, 08:06 PM   #15
T Hilde
Re: 1949 3600 build
$480 plus shipping out of Florida
Old 12-22-2009, 10:23 AM   #16
1952ssr
1952ssr's Avatar
Re: 1949 3600 build
That's well worth that. A person could go with tubular A-arms and that setup would be nice. Thanks for the info.
Old 12-22-2009, 12:00 PM   #17
bjcaldwe
bjcaldwe's Avatar
Re: 1949 3600 build
Neat setup, keep up the good work. If my frame was not already s10 clipped when I got it, I would definitely be considering this route.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 12-22-2009, 01:56 PM   #18
BlueJeep
BlueJeep's Avatar
Re: 1949 3600 build
Just curious, why?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-22-2009, 05:47 PM   #19
T Hilde
Re: 1949 3600 build
Just don't like the look.
Old 12-24-2009, 05:27 PM   #20
solidaxel
solidaxel's Avatar
Re: 1949 3600 build
Here is one that I used from Industrial Chassis Inc in Phoenix that uses Dodge Dokata suspension bolt ons, looks like the same idea that Scott is using only in Chevy
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-25-2009, 02:12 AM   #21
T Hilde
Re: 1949 3600 build
That looks good Solidaxle. How much was that unit?
Old 12-25-2009, 11:23 PM   #22
solidaxel
solidaxel's Avatar
Re: 1949 3600 build
I don't remember what the total cost was with all new replacable parts but I think it was a bit under the cost of a COMPLETE Mll set up.
The thing I liked about this set up is that it is a front suspension designed from a pick up the same size and weight as our AD trucks
LS 3 4L70E
Old 01-27-2010, 10:23 PM   #23
Scott Danforth
Re: 1949 3600 build
Todd, Nice Build - Looks like the same thread as the HAMB and Stovebolt.
Scott Danforth is offline   Reply With Quote
Old 01-28-2010, 01:30 AM   #24
nuke1
nuke1's Avatar
Re: 1949 3600 build
Very nice build there, i really like the front suspension clip idea, gives me an idea.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-28-2010, 09:51 AM   #25
99 to Life
99 to Life's Avatar
Re: 1949 3600 build
This truck looks awesome and in solid contion. Where did you get it?
Are you doing power steering? Any other updated mods? I am doing
and s-10 frame on mine, so everything is updated and accessible to get
parts for.
subscribed
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Thread Tools
Display Modes
