12-14-2009, 07:24 PM | #1 |
The oddest Todd around
How do you properly adjust headlights on 72 c10?
Title says it all... how do you properly adjust the headlights on a 72 c10?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
12-14-2009, 07:51 PM | #2 |
Re: How do you properly adjust headlights on 72 c10?
12-14-2009, 07:56 PM | #3 |
12-14-2009, 07:58 PM | #4 |
20' Daredevil (Ret)
It's easier than these sites make it look... but here we go: http://www.automedia.com/Aiming_Head...cr20010801ha/1
Here's another: http://www.ehow.com/how_4962528_aim-headlights.html Probably the most comprehensive: http://www.danielsternlighting.com/tech/aim/aim.html One more: http://www.midstatedmc.com/tech/aim.htm And there are many more. They all do about the same thing, so use whichever one is easiest to understand.
12-14-2009, 08:01 PM | #5 | |
Park on a flat surface about 30-40 feet from a wall (parking garages work well). Set the lights to low beam and adjust up/down so that the light cuts off about 2-3 feet up the wall. For the left/right adjustment you can push a little to the passenger side but if they are aimed low enough you can spill a good bit of light on the other side of the road and still not blind oncoming drivers. EDIT: Wow the above links are waaaay more comprehensive... but I've done fine just eyeballing everything. I also use Euro spec headlights which have a very sharp cut off so maybe they are a little easier to aim. Last edited by snowblind; 12-14-2009 at 08:07 PM. |
12-14-2009, 08:17 PM | #6 | |
I like the first one from automedia. Thats simple enough. |
12-14-2009, 08:56 PM | #7 |
I own a AC Delco headlamp aiming factory tool stop by if your in the neighborhood.
12-14-2009, 09:00 PM | #8 |
12-14-2009, 09:02 PM | #9 |
12-14-2009, 09:30 PM | #10 |
12-14-2009, 09:53 PM | #11 |
Me too.
Thanks y'all. That's why this board is so wonderful!
Thread Tools | |
Display Modes | |
