Old 12-15-2009, 11:48 PM   #1
texastrendz
a arm question
i am pretty sure this will work, just want to make sure. i want to put 73-87 arms on my 67-72 crossmember. this will work, right?
texastrendz is offline   Reply With Quote
Old 12-16-2009, 02:12 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: a arm question
The 73-87 arms will swap over just fine. Ball joint tapers are different... make sure the ball joints correlate to your spindle year. Ball joints for earlier spindles will press right in to the later arms.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-16-2009, 10:43 PM   #3
texastrendz
Re: a arm question
man that is service, how busy you are and your the only one that answered my question, thanks. any more news on that body drop kit yet
Old 12-16-2009, 11:13 PM   #4
kev2809
low n' slo
kev2809's Avatar
Re: a arm question
yes! looks like ill be getting your arms!
so i can use the 72 arm on my 67, as long as i use the 67 balljoints in the new arm?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-16-2009, 11:24 PM   #5
SCOTI
SCOTI's Avatar
Re: a arm question
Yes. You'll need the correct BJ for the spindle you plan to use.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-16-2009, 11:26 PM   #6
kev2809
low n' slo
kev2809's Avatar
Re: a arm question
good. my stuff is original except for the arms i should be getting. good to know, thanks scoti
-_--_--_ _________
Old 12-27-2009, 04:13 PM   #7
57larry
Re: a arm question
any advantage on using a 73 up A arms & spindles on a 72?
57larry is offline   Reply With Quote
Old 12-27-2009, 04:20 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: a arm question
73 and up 1/2ton use a rubber bushing 72 and down use a threaded steel bushing. which if your truck is lowered will provide more ground clearence. The 1/2 ton A arms will interchange with the correct ball joint.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-27-2009, 04:21 PM   #9
kev2809
low n' slo
kev2809's Avatar
Re: a arm question
ive never tried it but when i was looking it up the drop spindles were cheaper, and came in 3"
-_--_--_ _________
Old 12-27-2009, 07:59 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Re: a arm question
That's the main "advantage"... the parts are less expensive on the 73-87 than the 63-72.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-27-2009, 08:35 PM   #11
57larry
Re: a arm question
is price the only advantage?
Old 12-27-2009, 09:31 PM   #12
texastrendz
Re: a arm question
can you run a 73-87 upper and a 67-72 lower. i ask because i have already cupped a set of 67-72 lowers and have a nice set of 73-87 uppers. a lot of work to cup the lower arms is why i ask.
Old 12-28-2009, 01:47 AM   #13
SCOTI
SCOTI's Avatar
Re: a arm question
Yes, you can.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-28-2009, 12:47 PM   #14
Custom 68
Custom 68's Avatar
Re: a arm question
Like Scoti said you can but you must make sure you match your spindles to the ball joints. If you have 73 up the upper and lower have to be 73 and up ball joints regardless of what the a-arms came from.
Also don't forget the tie rod ends are different from 72 generation to the 73 generation.
I just swapped mine.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Thread Tools
Display Modes
