Old 12-18-2009, 05:10 AM   #1
texasfunk
texasfunk's Avatar
found this while welding mufflers back! is ths scary or what??
well,ever wonder what lowering kit is on my truck? PO got a little happy with the torch, i'll let the pics do the talking! also threw some random ones in there, turns out the entire exhaust was held on by hanger wire! so i bougth some brackets, and welded em up!
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 12-18-2009, 07:18 AM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: found this while welding mufflers back! is ths scary or what??
Boy, doesn't that make you feel all warm and fuzzy! Geez!
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 12-18-2009, 07:43 AM   #3
bigblock73
yeller
bigblock73's Avatar
Heated coils = no good...the drop shackles are fine however...despite the crude bed clearance.
bigblock73 is offline   Reply With Quote
Old 12-18-2009, 08:14 AM   #4
ironroad9c1
Master Hater
Yea, but the way they bent the rear spring spring isn't
ironroad9c1 is offline   Reply With Quote
Old 12-18-2009, 08:49 AM   #5
Stitch
Location: Where I come from, it's cornbread and chicken...
you should have two jack stands under the front of that truck and not one...especially if you're going to be on the side without one...just noticed that...
Stitch is offline   Reply With Quote
Old 12-18-2009, 09:47 AM   #6
bigblock73
yeller
bigblock73's Avatar
I didn't even notice that...I was eyeballing the shackle as that is what was centered in the picture.
Did they tighten down the shackle THEN try to attach the spring and realize it was too long to bolt up? I would assume if they bolted everything together loosly, then came back and tightened things down, they wouldn't have had to "modify" the leaf spring.
Either that, or they have the HD springs (longer) on a originally LD spring (shorter) truck.
Old 12-18-2009, 09:50 AM   #7
bigblock73
yeller
bigblock73's Avatar
I see two stands, look closly at the pic where he is under it.
Old 12-18-2009, 10:12 AM   #8
Wild83C10
Wild83C10's Avatar
It also looks like a bumper bracket bolt is missing? The bump stop on the LCA is also missing.
I only see one jackstand as well. It is positioned near the middle of the front crossmember. Always use 2 jackstands and let the jackstands support the load when you are under it.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-18-2009, 10:25 AM   #9
bigblock73
yeller
bigblock73's Avatar
I clearly see 2 in the last pic (one on each side of the jack)...get your eyes checked fellas!
Old 12-18-2009, 10:38 AM   #10
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
u guys crack me up!!
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 12-18-2009, 11:00 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Almost all of the lowered trucks I have looked at locally have been lowered just like yours.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-18-2009, 12:06 PM   #12
joe231
joe231's Avatar
that is certainly ghetto, but it appears to work ok
CHEVY ONLY
Old 12-18-2009, 12:41 PM   #13
Slonaker
Slonaker's Avatar
Until a spring, weakened by the heat, breaks.
Slonaker
Stock '01 Silverado
Old 12-18-2009, 01:03 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
So what are your suspension plans now?
Keith
Convert to disc brakes.
Old 12-18-2009, 01:21 PM   #15
Stitch
the two jack stands are on one side of the truck...granted, I didn't see the other jack stand until you pointed it out, but the one that's near the middle is not where it will prevent the truck from falling on him I wouldn't think...
Old 12-18-2009, 01:31 PM   #16
texasfunk
texasfunk's Avatar
yea, its pretty scary! and there are two jack stands, the trucks a arm mounting point is setting on them(idk what its called, its a long cylinder the lower a-arm mounts to) and the truck is solid on them, id never work on something that low, or even period if it wasnt held right, and the reason for melting the leaf was to get more drop, and you guys should see the coil compressed, wow, it is pretty bad, i had a set of extra leafs and springs for it from a parts truck, but am waiting to replace it all for when i buy a drop kit, i dont want a stock truck, so i was also contemplaing putting airbags all the way around, not anything major, just to replace springs, and give a little adjustment to the ride
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 12-18-2009, 01:37 PM   #17
lolife99
lolife99's Avatar
I would think those leaf springs would have the "pinion angle" all hosed up.
Keith
Old 12-18-2009, 01:50 PM   #18
texasfunk
texasfunk's Avatar
i agree that they do, the u joints looked pretty new, but everytime i shift i hear a clank, and its coming from there :S
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 12-18-2009, 03:43 PM   #19
dropd80s
dropd80s's Avatar
I have seen shackles sticking through the bed floor on a 88-98 before.
When my brother bought his 77 K10 it had 4" Rancho springs up front that had been heated in a "M" shape to lower it down to match the stock 3/4 ton rear springs. ghetto....
dropd80s is offline   Reply With Quote
Old 12-18-2009, 04:12 PM   #20
joe231
joe231's Avatar
shackles effect the pinion angle also...
CHEVY ONLY
Old 12-18-2009, 11:40 PM   #21
texassquarebodies
Truck Nut
texassquarebodies's Avatar
That shackle looks to alot more than a standard 2 inch. My Bell tech only has three holes.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 12-19-2009, 12:24 AM   #22
3r!c84
Badass
3r!c84's Avatar
you work like me.just throw yourr tools everywhere and pick them up next week or 2
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-19-2009, 12:54 AM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
Those coil springs look kinda like this?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-19-2009, 02:37 AM   #24
texasfunk
texasfunk's Avatar
wow! its like you got them right off my truck! i thot my ride got alot worse since then.....
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 12-19-2009, 03:56 AM   #25
texasfunk
texasfunk's Avatar
well chux! u joints gave out sooner then anticipated! was out at the local cruise and left the parking lot and all of a sudden a lud clunk and scraping! i roll into the center lane to see what in my rerview? my driveshaft in the street! luckily had some of the guys push me back into the parking lot, i had a roll of duct tape, yea, ghetto, got the needle caps, taped it up, and slowly puttered home! guess i have something to do in the morning!
1986 Monte Carlo SS
1955 Chevy Bel Air
Thread Tools
Display Modes
