Old 12-20-2009, 09:22 AM   #1
Patsfan34
Patsfan34's Avatar
What is the function of this wire to the Transfer case?
I'm sure I could research and find out what the wire to the T-case is but I figured it's much easier to ask you guys. What's the wire for that screws into the T-case? When I bought the chassis the guy had already sold the body and just cut the wire and let it hanging so I didn't get to see where it was hooked up or what it does. Thanks, Patsy!
Patsfan34 is offline   Reply With Quote
Old 12-20-2009, 09:45 AM   #2
msgross
msgross's Avatar
Re: What is the function of this wire to the Transfer case?
that's your spedometer cable, it often has a small adapter box right at the TC, this compensates for different tire sizes..
looks like a rockwell 221 transfer case, that was in 67-69's...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-20-2009, 10:09 AM   #3
Patsfan34
Patsfan34's Avatar
Yeah, the frame is a 68 GMC 4x4 SWB. Will I need to get this "adaptor box"?
Old 12-20-2009, 10:13 AM   #4
msgross
msgross's Avatar
Once you get the truck running you will have to see how far off your speedo is from a GPS. Then find an adapter to compensate, they screw on easily...
http://www.transmissioncenter.net/sp...n_______va.htm
http://www.speedometershop.com/ratio.html
The Garage:
Old 12-20-2009, 11:38 AM   #5
Patsfan34
Patsfan34's Avatar
Ok thanks alot msgross! I appreciate the help!
Thread Tools
Display Modes
