Old 12-21-2009, 09:33 AM   #1
84 400
Sb 400 club
84 400's Avatar
What gear ratio do i have??
I know it has been asked before but i am kinda confused. Looked on the web and still not sure.
For 2 rotations of the tire the pinon turns just over 3 revolutions. The drive shaft is still hooked up and the T case is in N.
This is the stock 10 bolt on a 1977 K10 heavy half with 34 swamper tsl's.
This does not seem right to me i would think the truck would have 3:73 or $:10 but from what i gather this ratio would put my gear set down near 273???
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-21-2009, 09:57 AM   #2
b454rat
Re: What gear ratio do i have??
Could be 3.08s, 3.42s. Check on the front diff for a tag held on by a cover bolt, if it's still there it will tell you the ratio.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-21-2009, 10:03 AM   #3
msgross
msgross's Avatar
or pull the rear diff cover and check the ring gear for numbers. it will have a ratio like 41:11 = 3.73 etc..
fill it back up with some synthetic oil and never touch it again for the rest of your life... unless you change gears.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-21-2009, 12:21 PM   #4
84 400
Sb 400 club
84 400's Avatar
yeah i did diff fluid last winter... No tag on the axle. well I do have a diff gau8rd ,ade up that needs install so i guess i will check then. Kinda bummed if its got 308"s
1985 C10 LWB Sold
Old 12-22-2009, 10:29 PM   #5
Mike C
Mike C's Avatar
You have one tire on the ground in the back when rotating? That is correct without an LSD. What trans came in the truck? TH350 or TH700? Better gears would have come with the TH700. My dad's '81 Jimmy had 2.56 gears, so it could be worse...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Thread Tools
Display Modes
