Old 12-22-2009, 10:20 AM   #1
xratt
xratt's Avatar
My drive shaft keeps breaking!!!! Major problem
First, I got the truck running, using the old home made 2-part drive shaft that came in the truck. Someone custom shortened it and stick welded on the output shaft. Well with all the new ujoints and carrier bearing support, it did not make it around the block before it broke the carrier bearing support off the truck and everything hit the ground.
So I pulled the shaft and had it rebuilt. $246 later, I had a newly painted, repiped and new yoked shaft. It's been 3 weeks now. Well last night it broke the carrier bearing support again. So my ride is sitting downtown, on the side of the road. Not good.
Any ideas on whats going on? it's got a 350th trans, and a stock rearend. All new parts in the middle. Now my ride is super low and has incorrect drive angles. C-notch in the rear. Would this cause things to break?
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 12-22-2009, 10:32 AM   #2
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: My drive shaft keeps breaking!!!! Major problem
If it broke that fast, it sounds like something is in a bind. Does it bottom out on the output shaft or at the support bearing? You need about an inch of travel for it to slide as you go over bumps. Is the truck on air or a static drop?
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 12-22-2009, 11:06 AM   #3
70 Suburban
Rods
can also look at a heavy duty carrier. Yes if you do not have the correct drive angle this can cause problems.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 12-22-2009, 01:39 PM   #4
truckdrivinsob
Gear Jammer
truckdrivinsob's Avatar
Had to get a slip shaft put on my drive line since my truck was lowered. Maybe drive shaft is pushing on carrier and snaping it off?
truckdrivinsob is offline   Reply With Quote
Old 12-22-2009, 02:31 PM   #5
xratt
xratt's Avatar
My truck is on air. It can almost put the bumper on the ground. I pulled the shaft out and had it welded at my buddies shop. This time I had it bad ass tig welded. We will see how long it goes. I am going by the drive line shop to have them look at it for proper angle. But I'm broke with the holidays and oh yeah, no job. So advice is what I'm looking for.
1955 VW Buggy, 2.0L
1978 Honda CB550
Old 12-22-2009, 02:42 PM   #6
onequickchevy
onequickchevy's Avatar
Might be time to junkyard crawl for a one piece shaft. It will be stronger in my opinion. Less points to break always seems like a better idea. Good luck with this, and finding a new job!
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 12-22-2009, 05:19 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
subscribed....my 2 piece vibes when I'm to low and going fast you can feel it come in to it as the air bags drop tap up and it goes away so I'm asumming its angle /// I think a wedge maybe in order yo corret pinion angle?...looking for more input..
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-22-2009, 05:53 PM   #8
Joemomma1
Joemomma1's Avatar
Head to the wreckers. Lots of 1 piece aluminums right now due to the cash for clunkers deal. Some are bent up but you can find them. I just picked up a spare for $15. Out of a ranger I believe, nice and thick. If you have other issues than just a weak bearing this wont help the problem.
Joemomma1 is offline   Reply With Quote
Old 12-23-2009, 01:48 AM   #9
Captainfab
60-66 Nut
It sounds lke you may have angle problems for one, but I'm willing to bet that you have that whimpy a$$ carrier bearing that hangs from the top of the crossmember? There's really no need to go to a 1 piece, you just need the heavier carrier bearing and the corresponding heavier 2 piece driveshaft.
Old 12-23-2009, 07:57 AM   #10
Woogeroo
CaptainFab,
there is a heavier/more sturdy carrier bearing?
Does it mount in the same place?
Please give us more details.
two piece drive shaft pictures with carrier bearing
-W
Woogeroo is offline   Reply With Quote
Old 12-23-2009, 10:09 AM   #11
xratt
xratt's Avatar
yeah, my carrier bearing support is very wimpy looking. Took Autozone three tries to get me the right one. It's the one with the mounting bolts front and back. Seems most of them had mounting bolts left and right, a better design in my opinion.
Well I had my buddy weld the mess out of this carrier now. Tig welded solid beads down both sides. So if it breaks now, I will be amazed. I also thought of another colperate. I'm pretty sure my back wheels are out of balance. I just had new tires put on the back a few weeks ago. A not so fancy, cheapy place. Well I can tell I have a little more vibration in the rear. So I plan on fixing that next week. Hopefully that helps too
1955 VW Buggy, 2.0L
1978 Honda CB550
Old 12-23-2009, 10:26 PM   #12
ampsyco
make sure your driveshaft angle is good. if your trucks lowered that might be why. wrong angles will rip a driveshaft to shreds in no time.
ampsyco is offline   Reply With Quote
Old 12-23-2009, 10:31 PM   #13
ampsyco
just saw your other thread.
you need a new driveshaft. that weld wont hold. you also have to remember that the driveshaft has balance. if you had it welded and not rebalanced your not fixing anything.
an out of balance drive shaft can make bad things happen.
id say get a new shaft. new u joints and check your angles. looks like that rear suspension isnt factory. so check your angles.
Old 12-24-2009, 01:49 AM   #14
Captainfab
60-66 Nut
Yeah, that's the whimpy one in your pics Woogeroo. Don't see too many like that around here, I wouldn't trust those in anything more than a stock I6. I don't know what GM was thinking when they came up with that POS
Here's a pic of the heavier one that I'm talking about. They were available on C10's and larger. My '63 C60 has the same carrier bearings and same size driveshafts.
Originally Posted by Woogeroo View Post
CaptainFab,
-W
Old 12-24-2009, 01:25 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x1000 on angle. my bagged s10 had a 2 peice shaft, could get very shaky at certain heights, could chew ujoints if driven at full lift alot.
That aside, that drive shaft looks like $hit, I would replace it even if it werent the cause.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-24-2009, 01:30 PM   #16
Hottrucks
Hottrucks's Avatar
did they make a LWB 1 piece driveshaft or do you have to have one made up??
I have a vib @ highway speed if I get at the wrong amount of drop or ds angle I was thinking of a axle wedge to help cure it??
Old 12-24-2009, 02:26 PM   #17
62gmc910
62gmc910's Avatar
the ujoints in theory should all have the same angle or you get the "squiggly mirrors" viberation on severe drop trucks you might have to offset the driveshaft to one side to get the nescisary angles. Somebody out there knows the secret but the first thing is get rid of the scabbed together mess and get the heavier steady bearing and shaft
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Thread Tools
Display Modes
