12-23-2009, 08:24 PM | #1 |
coil rear suspension.......
can bolts be used in place of u-bolts if so what kind? good idea or bad and why?
12-23-2009, 09:11 PM | #2 |
low n' slo
Re: coil rear suspension.......
if u take out the u bolt, and use a bolt, what will hold the axle down?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 12-23-2009 at 09:13 PM. |
12-23-2009, 09:17 PM | #3 |
Not with out some fabrication..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
12-23-2009, 10:50 PM | #4 |
67-72 parts collector,…
Don't do it.
I saw a nice truck destroyed years ago, because a guy did the same thing. (rearend came out from under the truck at 55mph on a corner) Get the proper u-bolts! |
12-23-2009, 11:55 PM | #5 |
i have the proper u bolts in it now i was just thinking cause i think they might end up hitting my notch and not allow it to fully lay out.
12-24-2009, 12:38 AM | #6 |
low n' slo
can u cut like an inch off the bottom of the notch or whatevery u need then plate it back up?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-24-2009, 01:54 AM | #7 |
the bolts would still tighten the the pad down which is welded to the rear. if you dont make a lot of hp, hydro jump, or do high speed driving i would say do it.
however, you would be safer to trim more of your framework to make it clear and keep the u bolt. |
12-24-2009, 11:12 AM | #8 |
Junior Member
I dont think I would guess for a 1/2"
Thread Tools | |
Display Modes | |
