01-02-2010, 02:22 AM | #1 |
More parts from late model truck 1986*
So More parts from the 'burb
Sunvisors Dark blue nice shape and tight. Passanger side has a Mirror 20.00 + shipping vacuum diaphragm cover for AC vent on passanger side 5.00 + shipping Heater AC controls lens nice, Blower motor switch knob broken off 20.00 + shipping Glove box door with non-locking knob, Glove box is no good 5.00 + shipping Rear-door bottom carpet panels fit rear dually doors also, needs cleaned plus there is a small rip/hole on one. 10.00 + shipping Last edited by chevybuldr; 01-02-2010 at 02:24 AM. |
01-02-2010, 02:34 AM | #2 |
Re: More parts from late model truck 1986
Throttle pedal assembly for cruise control
SOLD Throttle cable from 454 with cruise at Auto SOLD Complete hood hinge and spring assembly glass beaded and ready for paint 25.00 + shipping Door lock actuators tested and do work 15.00 EACH + shipping under hood wiring gutter not cracked or broken 5.00 Last edited by chevybuldr; 01-15-2010 at 02:16 AM. |
01-02-2010, 02:36 AM | #3 |
Silverado fender emblems plastic stick on these didnt use nuts on the studs on the back. Drivers does have the studs still on pass is broken off.
10.00 + shipping Vacuum operated vert door for under cowl NOT BROKEN 15.00 + shipping Last edited by chevybuldr; 02-15-2010 at 01:01 AM. |
01-02-2010, 02:51 AM | #4 |
Rubber wire grommets between doors and body On has a tear near the end about 1/3 away around
SOLD Windshield wiper motor from delay system 25.00 + shipping Outside door handles. Little pitting very nice shape driver quality 20.00 for BOTH + shipping Lots of other parts PLEASE tell me what you need. Power window rear gate REAR AC 3/4 ton 2wd suspension Rear pwer windows. Last edited by chevybuldr; 01-19-2010 at 10:17 AM. |
01-05-2010, 11:42 AM | #5 |
Ttt
01-06-2010, 05:41 PM | #6 |
How much is shipping on the visors to 78665. Also do you know if they can be dyed a different color?
01-06-2010, 10:26 PM | #7 |
01-07-2010, 11:42 AM | #8 |
Let me make sure these can by dyed, if they can and they stay in the up position, aren't scratched or cracked I'll take them if you can wait till next Friday :-)
01-07-2010, 01:22 PM | #9 |
There are no cracks that I have seen. might be some small scratches from normal use and they stayed up pretty good and not bent up. Let me know what you figure out please.
01-07-2010, 11:21 PM | #10 |
do you have the ac brackets for the engine
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
01-07-2010, 11:52 PM | #11 |
01-11-2010, 01:16 AM | #12 |
Right turn Clyde
thinking about these as well
Throttle pedal assembly for cruise control 10.00 + shipping Throttle cable from 454 with cruise at Auto 10.00 + shipping
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
01-16-2010, 12:21 PM | #13 |
Ttt
01-16-2010, 06:46 PM | #14 |
Addicted to Rust
upper door panel trim for left rear door? thanks Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
01-16-2010, 06:58 PM | #15 |
01-16-2010, 07:41 PM | #16 |
Addicted to Rust
Yes , but want one with no door pull straps. Jay
01-16-2010, 09:56 PM | #17 |
I believe this is what you are looking for. One has a broken stud. There are the typical scratches. I tried to get a good picture of the face but the flash was a killer. 15.00 shipped parcel post.
01-16-2010, 10:19 PM | #18 |
Front turn signals for dual headlight/behind grill front end. The light on YOUR right has a scratch on the upper left corner.
25.00 shipped Hood latch assembly for inside cab hood release. The hook has been glass beaded and the latch has been cleaned and greased. 25.00 shipped Shiffter linkage from column to tranny. Two different tranny linkage. Pitted from rust. 20.00 shipped Windshield wipper fluid reservore with spray motor. Not cracked or broken hold water and has cap. Unknown condition of the motor. One mounting point is cracked and broken, as seen in the picture 20.00 shipped All shipping is parcel post |
01-16-2010, 10:55 PM | #19 |
Let me know what number you need.
01-16-2010, 11:11 PM | #20 |
Passanger side door Latch assembly. It has been cleaned and greased.
25.00 shipped parcel post |
01-17-2010, 10:02 AM | #21 |
Location: Where I come from, it's cornbread and chicken...
do you have the wiring harness that's inside the cab for the power windows and doors...I have a crewcab that has suburban power doors on it...the doors have the harnesses in them, but the crewcab originally did not have power doors, so there is no harness in the cab to hook them up...also, I see that you have the door jam boots, do you have all four or just two...thanks alot...
Chuck. |
01-17-2010, 11:12 AM | #22 |
I do have the harness that runs under the dash and plugs into the doors. Unfortunatly it was cut on both sides (driver/passanger) under the front seat. You would have to splice them back together as I kept the whole unit . Also I do have the rubber boots for all the doors. One for the front door is ripped about a 1/3 of the way around. Look at message number 4.
Go here and look at picture 45 for the underdash harnes and how it was cut. http://67-72chevytrucks.com/vboard/s...=376980&page=2 |
01-17-2010, 01:25 PM | #23 |
that's what I need...how much do you want for harness and the door pieces shipped to a business address at 29151.
01-17-2010, 02:28 PM | #24 |
do you have the strips for the front door like in pic 17? and do you have the blue fabric part the go by door handle on in side for the front door?
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
01-17-2010, 03:10 PM | #25 |
How about 25.00 shipped
Thread Tools | |
Display Modes | |
