Old 01-06-2010, 12:11 PM   #1
stevieB
stevieB's Avatar
4 link install
so I am going to install a a triangulated 4 link on the blazer. I was thinking about intalling while the leaf spirngs were still attached with a flip kit and just going to the inside. Would this be ok, and should you intall the 4 link at ride height? or laid out? I just think if I were to intall this with the leaf springs on, it would limit the possibility of getting the rear end off center.
Any help would be appreciated.
stevieB is offline   Reply With Quote
Old 01-06-2010, 12:28 PM   #2
justpball
justpball's Avatar
Re: 4 link install
this is what i am doing, i bagged it with my leafs in, at ride height, measure from the front mount of the leaf to the center of the rear end and see where I can run a brace across the top of my frame and mount the upper bars and get that measurement and then order them from SD. oh and the top bars will be adjustable so i can set the pinion angle.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-06-2010, 12:35 PM   #3
stevieB
stevieB's Avatar
Re: 4 link install
Ok, cool, sounds like a plan, but can I mount the bottom bars on the inside without problems? Or can I mount the bottom bars in the existing front leaf spring hangers with slight mods.
Old 01-06-2010, 12:57 PM   #4
justpball
justpball's Avatar
Re: 4 link install
if you do it on the inside you will have to box the frame where the mount will be, you can put it in the same mount for the front of the leaf with no prob and just weld the tabs on the rear axle for the other mount
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-06-2010, 01:02 PM   #5
stevieB
stevieB's Avatar
Re: 4 link install
Sweet! This makes life easy. I will measure it out and order it. Then I will do the inside top bars first. Then mount the bottom bars in the hanger weld it to the axle and call it a day!
Thank you so much, I can see cleary now.
Old 01-06-2010, 02:09 PM   #6
justpball
justpball's Avatar
Re: 4 link install
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-06-2010, 09:00 PM   #7
78-5.3
78-5.3's Avatar
Re: 4 link install
stevieb could you take pics as you go!!!!!! im interested in the same thing!!!!!
what a 4 bar kit did you settle for !!!
78-5.3 is offline   Reply With Quote
Old 01-06-2010, 10:23 PM   #8
DownLowHoe
DownLowHoe's Avatar
Re: 4 link install
Just make sure that your 4 link is as close to parallel with the ground as possible at ride height.
DownLowHoe is offline   Reply With Quote
Old 01-07-2010, 10:06 AM   #9
Hertzdaddy
Re: 4 link install
Hey justpball, do you have a pic of the frame mount for the lower bar in that setup you showed?
Hertzdaddy is offline   Reply With Quote
Old 01-07-2010, 10:16 AM   #10
justpball
justpball's Avatar
Re: 4 link install
i will have to see if i can find one, this is not my burb, just a pic i found while reserching for mine
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-07-2010, 01:12 PM   #11
stevieB
stevieB's Avatar
Re: 4 link install
I will post pics as I go, I think I am going to go with suicide doors for the 4 link.
Thread Tools
Display Modes
