01-07-2010, 11:16 AM | #1 |
chevy truck fan
Squaring bed question
All,
I have a 1972 swb that I would like to “square” the bed on. I do not know how to, could you guys give me some guidance on how to make the bed square… Thanks!! Rodstored-72 |
01-07-2010, 11:21 AM | #2 |
Re: Squaring bed question
Is it a wood bed and you just want to make sure it's square? It should have been done when the wood was originally done/replaced, but the only way I know how to do it is put it all together loosely, measure, adjust, tighten, measure, adjust, etc. until everything is tight. It's a process but tha's the only way you can do it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
01-07-2010, 12:55 PM | #3 |
Active Member
Not sure what you mean by squaring the bed, but if it's just adjusting it so it lines up with the cab or is straight on the frame, here's what I did to mine.
I loosened up the mounting bolts and placed wood blocks on either side between the bed and the cab. I duct taped them so they wouldn't move and/or scratch the paint. I then pushed and manuevered the bed until both sides were touching equally (not forced) on both sides. I eyed both sides to make sure they were straight. forgot to mention: I placed mine 1-1/2" from the back of the cab. Last edited by 68gmsee; 01-07-2010 at 12:58 PM. |
01-07-2010, 03:03 PM | #4 |
chevy truck fan
all,
it is a steel floor bed & i am wanting to make it square related to the tailgate. dan42, so i guess i should loosen all the bed bolts? do i (should i) loosen the bed from the truck?? my main issue is that the tailgate does not shut good into the bed & the best i can tell the gate is pretty straight & not bowed.....i just want the gate & bed to line up good & the gate shut easy. thanks!! |
01-07-2010, 04:26 PM | #5 | |
Active Member
You could try to loosen "all" of the bolts holding the sides and fender wells but that would be a lot of work. Most of those bolts have rusted and usually break off when you try to remove them. Not sure that would buy much movement though. Don't forget, the bedsides have a tack weld on the backside that has to be cut. Might also want to post some pics so we can get an idea of what it looks like. |
01-07-2010, 04:59 PM | #6 |
I'm thinking that it was probably loaded with dirt with a front loader or something, where you had a bunch of weight fall into it all at once, and you might have twisted it. I have seen beds do that before. Like 68gmsee says, have a body guy look at it.
01-07-2010, 08:22 PM | #7 |
I also have a Question related to this. I have a 68 Chevy 1/2 ton lwb and the box on the drivers side sticks out more behind the cab then the passenger side. Can I just loosen the bolts that hold the bed on and move it ?
01-07-2010, 08:27 PM | #8 |
Active Member
Thread Tools | |
Display Modes | |
