Old 01-16-2010, 03:41 AM   #1
bucannon
Salty Sailor
bucannon's Avatar
Arrow 86 C-10 needs more ride height
ive got an 86 2wd c-10 custom deluxe with 31" x 10.5" tires on stock 15" rallye rims, with stock suspension. ive noticed the drivers side is sagging and the suspension is so damn noisy! it sounds like a bucket of bolts riding down the road!
i plan to get junkyard sourced 4wd rear springs and replace mine
then order LMC's heavy duty front coil springs and ball joint spacers if necessary
i wan to have more ground clearance and i want to run at least 33's without them rubbing
what do yall think?
i also have 3" rear lift blocks sitting in my garage, should i use them?
does anyone have pictures of anything like this?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 01-16-2010, 09:06 AM   #2
Curly86
You want it there when???
Curly86's Avatar
Re: 86 C-10 needs more ride height
Sounds like a plan I am goin have to do my 86 too. The previous owner heated the front coils to lower the front end and it rides like s$$t. Got to change my rear springs so I can pull my car trailer with it.
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 01-16-2010, 09:10 AM   #3
JohnC
JohnC's Avatar
Here is a pic of my truck when I first got it. It had Fabtech 3" lift coils up front with ball joint spacers, and blocks in the back. The tires were 31x10.50's if I remember correctly on 15x8 rims.
JohnC is offline   Reply With Quote
Old 01-16-2010, 10:56 AM   #4
Prerunner1982
Prerunner1982's Avatar
My 82 ran on 32x11.50x15s with minimal rubbing. It had stock rear leaf springs and HD (1ton/Diesel) front coils.
The front tires rubbed on the inner fenders, but it was something I could live with as there was nothing there to cut up the tires. As far as running 33"s, depending on how wide they are you may have rubbing problems at the bottom of the front fenders. With my 32x11.50s I had less than 2 finger widths between the tire and fender at the closest point.
The picture below is with the tires straight... I couldn't find the one with them turned.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-16-2010, 11:41 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
what i did on my old 86 was to put the seven leaf pack that had been re arced in the rear and 3/4 ton springs in the front and got a nice ride height on it. You can put on a 3" lift to give it more height if you want then your 33s will look nice and the truck will sit great.. mine was a 4.3 with a th400 trans and it sat as nice as some of the 4X4 blazers and could haul anything
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-16-2010, 11:41 AM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
hd coils, 3" body lift on 235 85 16
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-16-2010, 03:54 PM   #7
kris's66lwb
resident wrencher
im runnin 31 13.5s in the rear with out any rubb just put the f44 big ten 5 leaf spring on it int the rear it sits like a 3/4 in the back and im running 265 65 15s up front with out rubbing with light duty 1/2 coils to make it sit higher and be able to run 33 pu hd 3/4 coils up front itll ride like a brick but itll clear and have some deeper offset rims
kris's66lwb is offline   Reply With Quote
Old 01-16-2010, 04:56 PM   #8
78 Chevyrado
Mine's a 3/4 ton, but this is what I've done to it. It had light duty 3/4 ton front springs and heavy duty 3/4 ton rear springs. I swapped out the front coils to 3/4 ton heavy duty, and put 1.5" lift blocks in the rear. The tires are 265/75/16, or approx 32" tall.
78 Chevyrado is offline   Reply With Quote
Old 01-19-2010, 09:16 PM   #9
bucannon
Salty Sailor
bucannon's Avatar
thanks yall
Savannah, Georgia
Thread Tools
Display Modes
