Old 01-16-2010, 01:48 PM   #1
blk65fleet
blk65fleet's Avatar
master cylinder
i am going to keep the manual brakes on my truck but i have converted it to disc/drum now and need to know if there is a trick instead of buying a new one from cpp.
blk65fleet is offline   Reply With Quote
Old 01-16-2010, 02:49 PM   #2
62gmc910
62gmc910's Avatar
Re: master cylinder
Are you using a dual line system with a "proportioning valve"
Usually the best thing to do is to use the MC for the donor truck that the discs came from check the FAC sticky to see if the disc threads are there yet
Captainfab makes adapters for master updates
if you have more questions give us more details as to your plans
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-16-2010, 02:53 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Re: master cylinder
When I first put disc brakes in the front of my 1960 I just bought a stock manual master cylinder for a 1975 from Napa. Don't remember for sure if this is the one, but it shows the pricing for something comparable:
http://www.napaonline.com/Search/Det...+50014+2014024
Old 01-16-2010, 03:18 PM   #4
62gmc910
62gmc910's Avatar
Re: master cylinder
markeb01 Have you checked out the FAC sticky yet , I thought about you when it got posted , you always seem to know where to link for info , maybe you could do a link post
Old 01-17-2010, 01:11 AM   #5
Captainfab
60-66 Nut
Re: master cylinder
All you need is a manual master cylinder for a '71 or newer truck with disc/drums. It will bolt right up to your firewall. You might have to modify the pushrod though.
Old 01-17-2010, 01:59 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Re: master cylinder
I'll take a look at that and see if I can offer something of value. Thanks for the tip.
Old 01-18-2010, 11:41 PM   #7
blk65fleet
blk65fleet's Avatar
Re: master cylinder
do you know if it would have to be a truck mc for it to bolt up because my buddy just built a hot rod with manual disc/drum brakes and he used a 72 vega mc would that work for me
Old 01-19-2010, 01:25 AM   #8
Captainfab
60-66 Nut
Re: master cylinder
I don't know about a Vega master, but most passenger cars should have the same bolt pattern. I would suggest using a truck master on a truck since it will have the correct bore to work with your truck sized wheel cylinders. It shouldn't be any harder to find a truck specific master at the parts store than a passenger car master.
Don't forget you'll need the proportioning valve as well.
Old 01-19-2010, 01:36 AM   #9
62gmc910
62gmc910's Avatar
Re: master cylinder
I agree with Captainfab on this unless you really know what you doing mixing up brake parts can be mayhem
Old 01-21-2010, 01:29 PM   #10
blk65fleet
blk65fleet's Avatar
Re: master cylinder
alright thanks guys
Thread Tools
Display Modes
