![]() Join Date: Jun 2007
rear cab mounts
will the rear cab mount rubber bushings for the 50-53 model trucks work when rebuilding the rear center cab mount on a 47-48 cab? or does anyone sell a bushing set specifically for the 47-48 cabs? thanks...
Re: rear cab mounts
According to the catalog I have they are the same but I am not positive that is correct.
I can measure the new ones I have that haven't been installed yet that fit the side of the frame mounts and give you the measurements if that will help. |
Re: rear cab mounts
that would be a big help. thanks!
Re: rear cab mounts
On the rubber bushing
Od right at 7/8" with the half inch bolt in place Id 1/2" Depth to shoulder of bushing 1" Total length of bushing 1-1/8" All measurements taken with my dollar store plastic caliper. |
Re: rear cab mounts
thank you! i am going to pull the mount off the bottom of the cab in the morning so i will be able to compare measurements.
Thread Tools | |
Display Modes | |
