01-27-2003, 08:22 PM | #1 |
Got earplugs?
squek??
OK, if i am driving slowly and i try to turn, the truck squeks, is this just the power streering pump not strong enough to turn the tires(they have about a 9-10" wide tread), or is this another problem? Thankx for any help.
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
01-27-2003, 08:55 PM | #2 |
is it a fan belt squeek or som other kind of squeeling, if its a beld its probly loose or worn out. it shouldnt have that much play in it. o ya i dont have power steering
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
01-27-2003, 09:48 PM | #3 |
Got earplugs?
No it's not a belt, it's only when i turn.
01-27-2003, 09:55 PM | #4 |
Used to have a truck
When i first got mine I was having the same problem with mine until I figured out one of the front shock mounting bolts was way loose where it attached to the frame. Tightened it up and the squeek went away.
No truck :-( |
01-27-2003, 09:58 PM | #5 |
Got earplugs?
Thanks for the help mike
01-28-2003, 12:38 AM | #6 |
its all about the +6 inches
There are plenty of things it could be, and a pump would be on the bottom of the list IMO.
I belt may slip since you are putting more load on the pump and creating more drag. A shock bushing may be loose. An A-arm may be needing lubed. The anti roll bar (if equipped) may have worn bushings. A cab mount culd be going bad. Many other things. If you sit at a complete stop and crank the wheel all the way to the stop, you'll get an ear piercing noise, this is what a steering pump will sound like 9 times out of 10 when going bad. |
Thread Tools | |
Display Modes | |
