Old 01-18-2010, 11:42 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
72 Chevy 4x4 Frame with 4'' lift
HAve a 1972 chevy Factory 4x4 frame with Rough Country 4'' front leaf springs.
$400 for frame and lift
Also have the 1/2 ton axles from it, they have newer brakes on the front and back It is a dana 44 front and 12 bolt rear
$200
Call me at 314-267-9888 with any questions
I am located south os St. Louis about 30 miles
I need this stuff gone so I can buy some Rockwell Axles !!!! or a Chevy dana 60 front
Make OFFERS
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 01-19-2010, 04:09 PM   #2
dabels23
dabels23's Avatar
Re: 72 Chevy 4x4 Frame with 4'' lift
Do you have any pics
dabels23 is offline   Reply With Quote
Old 01-19-2010, 05:05 PM   #3
6600DURAMAX
I do have pics, but for some reason I cannot post them.
If anyone wants pics just send me an email and I will forward
thanks
Phil
Old 01-19-2010, 05:25 PM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
location, location, location..
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-19-2010, 06:22 PM   #5
6600DURAMAX
South of St. Louis
Zip Code 63028
Old 01-19-2010, 10:19 PM   #6
nbrfd007
nbrfd007's Avatar
Long or Short wheel base?
nbrfd007 is offline   Reply With Quote
Old 01-19-2010, 10:35 PM   #7
6600DURAMAX
sorry about that guys I thought I covered all my bases, forgot one of the most obvious questions.
Long Wheel Base
Old 01-21-2010, 04:02 PM   #8
6600DURAMAX
Ttt
Old 01-21-2010, 08:16 PM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Here ya go Phil:
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-21-2010, 10:54 PM   #10
6600DURAMAX
Thanks 71, appriciate it
Old 01-25-2010, 01:59 PM   #11
6600DURAMAX
$500 for frame, front springs and axles................
Someone come and get this from me
thanks
Old 01-25-2010, 02:01 PM   #12
6600DURAMAX
4.10 gears front and rear, with a spool in the rear
Old 01-31-2010, 12:07 AM   #13
silver7
silver7's Avatar
Awesome deal. Great start for a custom 4x4 hot rod. Bump for you.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 02-01-2010, 08:44 AM   #14
6600DURAMAX
Never thought it would be this hard to get rid of this
TTT
Old 02-01-2010, 11:31 AM   #15
nightmare
nightmare's Avatar
If you weren't so far away, (and i had the extra for it) i'd come and get it.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 02-03-2010, 05:39 PM   #16
1968filbilly
If you still have it, I'm highly interested. Currently in Afghanistan and won't be home till mid-April, or if you can trailor it outside of KC, MO for extra, maybe we can work something out. Thanks.
1968filbilly is offline   Reply With Quote
Old 02-15-2010, 01:38 PM   #17
6600DURAMAX
With my current luck of getting rid of stuff I will still have it !!!
I also have a set of 2wd big block mounts but I am afraid to list them!!!
TTT
Old 02-15-2010, 08:35 PM   #18
silver7
silver7's Avatar
If I knew then what I know now I would have started building my truck with a set-up like this. What a deal guys. If I had more room I would buy it and keep it for later! Bump for you.
Shawn
1971 C10 4x4
Old 02-16-2010, 02:07 AM   #19
IndyRich
IndyRich's Avatar
So I am interested....I live in Indy and have a 72 GMC c10(c15) with a 402 BB and a 400 Turbo trans that I would love to convert to a 4x4. Other than the transfer case....what else besides switching my cab, bed, engine, doghouse, etc. over would I need for this?
Such as steering? bumpers? radiator core support? would all that convert without alterations? What would I need to do to my transmission to hook up to the 205 transfer case, or would I need a whole new tranny?
Also do you have any way of getting it to Indy, OR meeting me half way?
Sorry so long Thank you for your time,
Rich
IndyRich is offline   Reply With Quote
Old 02-16-2010, 09:39 AM   #20
6600DURAMAX
You need a divorced 205 transfer case to be able to run your 2wd TH400, you need a 4wd tranny tunnel or just run a 2'' body lift, Steering is already on the frame (it consist of a factory 4x4 box and a raisd steering arm), all the body should transfer with little or no modifications, probably need to get 4x4 body bushings.
I do not really have much time to help get it to Indy, sorry but work is hectic lately.
There are a bunch of great threads on this site about converting from 2wd to 4wd, do some searches and you should be able to find a bunch
Give me a call if you have any questions
314-267-9888
thanks
Old 03-08-2010, 09:07 AM   #21
6600DURAMAX
Sold sold sold.............. Finally sold!!!!
Old 03-16-2011, 09:13 PM   #22
RShaips
I wish I had seen this sooner. I really could have used the axles! You're close too!
RShaips is offline   Reply With Quote
Thread Tools
Display Modes
