Old 01-21-2010, 10:35 AM   #1
BTCHN 1963
BTCHN 1963's Avatar
60-66 4x4 QUESTIONS
I just aquired a 1963 3/4 ton long box 4x4 and I have a couple of questions.
1. I want to update the suspension to newer 73-87 3/4 or 1 ton disk, disk. The rear end has been switched to a 14 bolt full floater but it still has the 3/4 ton dana 44 front with drum brakes. Do you guys just change the nuckles with a newer 3/4 ton dana 44 or is there a doner that has the same perch width. I measured the purch width last night and compared it with my 74 blazer and it is about 3/4 of an inch narrower, that is why I was asking if you guys just change the knuckles. Any suggestions would be great.
2. My other questions is about the transfer case. Do you guys keep the T221 or do you replace it with something else? If I remember correctly ford and dodge made a divorced NP205. I have both NP203 and 205 married transmissions.
My plans for the truck is to make a tow rig for my wifes horse business with ocasional light off road. I will strech the frame and make it a crew cab long bed. For motor and transmission I am going wtih a 350 tbi set up and 700r4 transmission.
BTCHN 1963 is offline   Reply With Quote
Old 01-21-2010, 10:33 PM   #2
1969K10
1969K10's Avatar
Re: 60-66 4x4 QUESTIONS
Generally, you'd just swap axles w/ a disk one, but from 67/68 on, they're all the same axle width spacing. I think it'd be real expensive to convert one.
As far as the 221 goes, they are difficult and expensive to find parts for. that being said, i liked mine much more than my 205.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-22-2010, 10:16 AM   #3
'63GENIII
'63GENIII's Avatar
The D60 that I have is out of a 73 Dodge (makes having an e-brake a little challenging) and the D44 front is out of a 72 Chevy. I don't think swaping the knuckles is an option and the swap is just cheaper. The T221 is a good t-case but a little loud and a little more maintenance than a 205 (probably not quite as strong too), but it's held up fine behind the 396. I pick up a Vortec 454 tomorrow and when that goes in, the 221 gets swapped for a divorced np201 with twin sticks and parking brake on the t case Many of the later model parts fit quite easily as there were not alot of changes to stuff like axle width and engine mounting so swapping can be fairly easy. I love my '63! Enjoy!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-22-2010, 11:19 AM   #4
LeftCoast32
Custom Builder
LeftCoast32's Avatar
I have a 1966 K10 that I am updating and converting all the frame hangers to the 1971-1972 Blazer/Truck. I started a thread on the frame dimensions and there is alot of great information and pictures.
I am installing the 1 1/4 Ton D60 Front and 14 Bolt Rear both with Disc Brakes and 4.56 Gears.
I still have the original 283, SM420 and T221. I plan to eventually swap the Divorced T221 for a Divorced NP205. The only problem with getting rid of the T221 is that it performs perfectly and I have always said "If it aint broke dont fix it". GM used the T221 all the way up to 2.5 tons so it is a tough unit. They are just a little loud and tend to leak at the rear output seals.
http://67-72chevytrucks.com/vboard/s...d.php?t=381963
LeftCoast32 is offline   Reply With Quote
Old 01-22-2010, 09:07 PM   #5
'63GENIII
'63GENIII's Avatar
Agreed! Mine's been abused for the 45+ years. Just loud and leaking!
Chris
'63 k15 long step
Old 01-23-2010, 09:24 PM   #6
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
I know this is not a 1963, but is this what you had in mind?
66Gilbert is offline   Reply With Quote
Old 01-23-2010, 10:36 PM   #7
NEVERENOUGH
NEVERENOUGH's Avatar
What are the specs on this truck. I am tossing the idea around of starting the rebuild on my 66. I understand that this is a photoshop but was just wondering on tire size and lift size if possible.
NEVERENOUGH is offline   Reply With Quote
Old 01-25-2010, 10:24 AM   #8
BTCHN 1963
BTCHN 1963's Avatar
Thanks guys for the great information! Based on what you guys said, I will run the t221 until it brakes.
Neverenough, that is exactly what I was planning on building. My wife was asking this weekend if it could be a flat bed instead of a conventional bed so I may go that route. Thanks for all your help!
Rob
Thread Tools
Display Modes
