01-21-2010, 08:47 PM | #1 |
Hitch Receiver with a rear roll pan?
Can anybody tell me if you can install a hitch receiver if you have a rear roll pan and no rear bumper?
If it is possible would I need the "hidden hitch" type Thanks |
01-21-2010, 08:51 PM | #2 |
Re: Hitch Receiver with a rear roll pan?
I had one welded on by a local hitch shop when I had a roll pan. It was set up to go behind the license plate.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-21-2010, 10:45 PM | #3 |
Big Red - Now its a SWB!
I think that ece and cpp both make hidden hitches for our trucks.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
01-21-2010, 10:52 PM | #4 |
Yup, that's what you are looking for. A "Hidden Hitch" and a rollpan with a flip down licence plate (er... tag)
01-21-2010, 10:58 PM | #5 |
When I was shopping, and this was probably seven years ago, I thought that the hidden hitch was just a tad too low for a roll pan. I could be wrong, as my memory isn't all that great. You will want to do measurements yourself, but don't order that one without measuring. I am pretty sure a bumper will sit a couple inches lower than a standard roll pan.
01-22-2010, 08:40 AM | #6 |
I just installed an ECE hidden hitch. I don't know if a roll pan is low enough however I also installed one a few years ago in my 89 GMC 1500 and it was perfect with a roll pan in that trucks. I could measure anything if you need me to.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-22-2010, 08:59 AM | #7 |
Big Al,
I made a custom roll pan out of diamond plate for my 69 so it is different than a standard roll pan. If you could give me the measurement from the bottom of the frame rail to the top of the receiver bar that would tell me a lot. All the hidden hitches I have found say "not for use with roll pan". Also my license plate bracket is tucked up behind the roll pan in the center so I will probably have to move it. Thanks for any help you can offer |
01-22-2010, 02:50 PM | #8 | |
Ok I will measure it tonight.....
01-22-2010, 09:41 PM | #9 |
I don't think the ECE hitch will work with a rollpan...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-23-2010, 12:26 AM | #10 |
I don't either:
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
01-23-2010, 08:01 AM | #11 |
I don't think it willl either but a regular hitch might?
Here is a rear view with the roll pan, not a good close pic but you willl see my problem |
01-23-2010, 04:45 PM | #12 |
Hart Rod,
If that is the ECE hitch that you have then I know it won't work because it would clearly show below my roll pan and because it extends out so far past the frame rail it would also interfere with my new tailpipes. Thanks for the great photo and the red line was a nice touch Steve |
01-23-2010, 05:31 PM | #13 |
Steve I measured it and definetly it will not fit........
01-24-2010, 08:28 AM | #14 |
Thanks Big Al,
I really appreciate you checking, ECE said the same thing, no roll pans |
Thread Tools | |
Display Modes | |
