Old 01-23-2010, 02:35 AM   #1
ct4613
Need some advice... Just got started
Just pulled my 66 into my shop this mornin, its been sitting inside my dads machine shed for the last 10 years, and i'm wondering, where do I start??
Dont have much money, just bought my farm last fall so I have a pretty tight budget now that i'm a homeowner. Here is my plan. Safety first. Ordering new brake line kit/drums/pads. Also new ball joints. I want to do a static drop, and my springs front and rear are shot. I've seen a kit with springs for front and rear, and shocks for about 600 bucks i think. THinking of eventually dropping it 4" in the front and 5-6 in the rear. So would the spring kit be a good start, and then buy the drop spindles later? Going to do the bodywork myself, i'm just going to clean it up and fix a couple dents/rust spots and shoot it with a flat black primer for this year. Last question for now. I traded for a set of 20" wheels that were on a 02 chevy half ton, that i dont beleive will fit on my 66 because of the large diameter center hub.(they are 6 bolt hubs on my 66) Does anybody make an adaptor plate so i can put more current wheels on my 66. Dont want to spend money on tires(mine are pretty dry rotted) if i can buy adaptors for these 20" wheels i have. Ok i'll stop with the questions for now. Cant beleive i waited 10 years to start on this!!! I think there are going to b some late nights in the shop. I work on dads tractors/combines/and other farm equipment all winter long, but its pretty hard to make a tractor COOL.
ct4613 is offline   Reply With Quote
Old 01-23-2010, 10:49 AM   #2
62gmc910
62gmc910's Avatar
Re: Need some advice... Just got started
Welcome to the site if you search around there is some stuff about newer wheels maybe check 70suburbans threads/posts he also did a 6 bolt disc with newer parts
Get pics start a build thread
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-23-2010, 01:07 PM   #3
Captainfab
60-66 Nut
Welcome to the forum
If you take a look thru the '60-'66 FAQ's at the top of the page, there will be a lot of info there to help get you started. One in particular is the "Front disc brake reference thread". That will help you with the wheel fitment issue and suspension mods.
Old 01-23-2010, 07:05 PM   #4
DPowers
DPowers's Avatar
Welcome to the site and congrats on the truck. I would offer some advice to not tear it all apart all at once- but rather take it a step at a time so that you can drive it while you are working on it. Make your self a plan and write it down seems to help as well.
Oh Yeah- We want to see pics too...
DPowers is offline   Reply With Quote
Old 01-23-2010, 11:25 PM   #5
robby5323
I second this... Do it like you eat an elephant.... One bite at a time...
robby5323 is offline   Reply With Quote
Old 01-24-2010, 12:58 AM   #6
BMSJaX
BMSJaX's Avatar
Ya dont rip it apart. I did this once thinkin it would be easier... two years later I scrapped the car. I would start with replacing all brake components, adding a '70 Impala dual line(drum/drum) brake master cyl. Then I would suggest the wiring. I find it easier to get the wiring repaired/replaced first, including running wiring for upcoming additions(HEI, electric fan, radio, better headlights, etc) that way your not constantly chasin gremlins or having to run wire here and there and splice into that line... oops that was a ground not a power etc.
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 01-24-2010, 01:10 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
Geeez what ever happen to...
You guys used to just jump at it..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-24-2010, 01:42 AM   #8
Captainfab
60-66 Nut
Well since Joe231 went to "the other side" he isn't here to enforce it as much.
Old 01-24-2010, 02:08 AM   #9
Slow Build
Slow Build's Avatar
As long as you understand that when you put drop spindles on later you will need to change to disk brakes in front. Anything that you do front drum brake-wise now will be removed later.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-24-2010, 03:09 AM   #10
LILRED66
LILRED66's Avatar
Welcome to the forums from Kansas City, KS and congrats on getting started on your '66. Pics are good, but a good plan is important to keep you and your project on track. Good luck and keep us posted on your progress.
LILRED66 is offline   Reply With Quote
Thread Tools
Display Modes
