Old 01-23-2010, 08:55 PM   #1
mr mike
mr mike's Avatar
can you bend billet aluminum or how would i bend it
Ok the new 2010 chevy camaro grill emblem i got is sold billet aluminum i was thinking it would look great on the front of the 69 c-10 but the angle is off how would i go about bending it out with out snapping in 1/2 or will it not snap just bend if you have any ideas let me know
pic to show what i am talking about
mr mike is offline   Reply With Quote
Old 01-23-2010, 09:17 PM   #2
LONGHAIR
Re: can you bend billet aluminum or how would i bend it
"Billet" in and of itself means nothing as far as bending the part. Billet is simply cut from a solid block....not a "casting".
The important thing here is the actual grade of the alloy. The higher grade alloys are "harder" and thus take to polishing much better, they also retain the polished finish much better. Unfortunately, this may also make it harder to bend.
So, after all of that, what it comes down to is....It depends.
It depends upon the alloy you have and how much you intend to bend it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-24-2010, 12:35 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and, if it is a factory production piece, I highly doubt it is billit.
Old 01-24-2010, 03:24 AM   #4
mr mike
mr mike's Avatar
This is the one I got its after market
http://www.latemodelrestoration.com/item/EMP-CM261P
Old 01-24-2010, 05:20 AM   #5
cdowns
cdowns's Avatar
i'd take a block of rubber and shape it for a base to mount it
or you can get a very sinilar emblem that is straghter from something like an HHR
Old 01-24-2010, 09:24 AM   #6
aboveall
Junior Member
bring to machine shop i had aluminum bent from them couple times they have press machines and stuff to fo that
aboveall is offline   Reply With Quote
Old 01-24-2010, 10:42 AM   #7
bigsnookmaster
bigsnookmaster's Avatar
A thin relief cut on the backside would make it bend a lot easier.
bigsnookmaster is offline   Reply With Quote
Old 01-24-2010, 12:09 PM   #8
68gmsee
Active Member
68gmsee's Avatar
My experience in bending aluminum is that it's "iffy" as mentioned above. The few times that I've tried, it developed hairline fractures on the stretched side and if I incresed the bend, it broke.
Someone mentioned taking it to a shop. That would probably be the best option. I'd take it to a shop that specialized in aluminum welding and machining. That part is too expensive to experiment on.
68gmsee is offline   Reply With Quote
Old 01-24-2010, 12:44 PM   #9
mbgmike
w/o knowing the grade and temper. If its an 1100 series with an O temper it can bend
I would put it in a press
Thinking about it however, its such a steep angle. If you were bending it more it would probably work ok. But trying to flatten it out it may not work out so good. I think the angle is too steep. I would still try and put it into a press and see what it does. If it springs back it has a high temper and won't bend. It will break. If it stays it has a lower temper, you just have to see the amount of spring to tell w/o knowing the info on it.
mbgmike is offline   Reply With Quote
Old 01-24-2010, 06:45 PM   #10
mr mike
mr mike's Avatar
I think you are right, its to expensive to play with. Ill take it to a shop Thanks for the info
Old 01-24-2010, 07:11 PM   #11
mbgmike
Thats the best way and besides if it broke I would feel bad and feel obligated to replace it.
Old 01-25-2010, 07:51 AM   #12
mr mike
mr mike's Avatar
lol well I wound not hold it to ya but i do thank you for all the info.
Thread Tools
Display Modes
