1972 Chevy Cheyenne Super
Cleaning, Degreasing engine, tranny, and frame - Tips and Best Practices?
I've got my truck torn down to just the rolling chassis and drive train.
I want to clean it up as I don't think it's been washed in 38 years. I'm looking for some tips and best practices for power washing the engine, tranny, and chassis. I've heard use water, oven cleaner, Simple Green, and water in that order. I also know I need to seal off my carb, distributor, transmission lines, and A/C box. Anything I'm missing? Thanks folks! You rock ![]()
-Clayton 1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen |
Grandpa in the rustmobile...
Re: Cleaning, Degreasing engine, tranny, and frame - Tips and Best Practices?
free bump i wana know too
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
A couple cans of degreaser and a trip to the local carwash.......unless you have a pressure washer.
GROVE STREET CUSTOMS est. 2005 ![]() 67' C10 LWB/350/T400 69' C10 SWB/454/T400 71' C10 LWB/383/ 72' C10 SWB/350/T350 15' Crew Silverado/6.2 |
get some oven cleaner, the cheap stuff. spray on, let soak in, spray off with a hot pressure washer, cuss that it needs more...repeat
how many cans of oven cleaner?
I plan to do, cab on back. and rear axle and trailing arms. pressure wash oven clean presure wash wire wheelin pressure wash let dry wipe down with mineral spirits primer dry primer dry paint dry paint dry sound good lol also, how many cans of paint do i need for this and how many cans of primer? and should i use self etching primer? any brand recommended?
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
TOTY 2006
![]() Join Date: Dec 1999
can't say how many cans, you will have to try and find out for yourself. you have over 40 years of baked on grease and dirt, so, who knows?
I would start with 2 cans and let everything soak for a day (less if you cover up with saran wrap) then scrap all the soft stuff off with putty knife, spray one more can, soak, then with a pressure washer or a jet nozzle on your garden hose, spray. Wear clothing you dont care about, and wear googles. take a picture of yourself when done so we can see how soaked and greasy you get. ![]() |
well really hate to por 15 heard it can be rough stuff lol
I THINK we have everything to spray paint with..never done it like to get by with a rattle can.... you guys are sorry lol wanna see how dirty i look heck i cant stay clean under my truck its ICKYYYY lol its just a DD but wanna clean up while im down there
Moderator
Then just keep using rattlecans as needed.
lol well its my DD and i live in the country and dont wanna run short.
5 cans of each? i dont care to put it on thick lol 10 cans of each?
Redefining LowBudget
use Castrol super clean..buy a gallon at wally world..put it in a spray bottle ( I use the big punp one like you use in the garden) spray it a couple times let it sit then hose it off...if you spray it on a damp day it works better...do that a couple times to get it clean....trust me not alot of scraping..then back to wally world for a couple/ few of those cheap paint brushs and a can of satin black rustolium and then just brush it on...I have done all my DD's and if theres a little oil left over it will mix in a bit shhhh dont tell...it will also clean up the inside of a beat up bed pretty well I use a 4" foam roller for the bulk and a brush in the corners.....looks good and is easy to touch up after hauling wood or junk .it wears alot better and cleans up better than a rattle can....
oh keep it away from any shiney aluminum parts or plan on some polishing time...and its pretty harsh on spray painted stuff too.....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Cruzin
as far as paint goes i use the rustoleum in the quarts i have used the stuff in the eastwood catalog but the rustoleum works as well to me and you can get it at wal-mart, lowes etc. and its about 8-9 dollars a quart or use the rattlecan rustoleum i just like to spray with a paint gun though
#13 |
1st) Use a sharp spatule and remove all the chunks of dirt,mud and grease.
2nd)use about 4or5 heavy duty engine degreasers (not oven cleaners or engine brite cleaners) for oven cleaners you will need a front apron ![]() 3rd)spray engine degreaser on motor frame etc. wait 5to10 min. and pressure wash it. 4) spray it again, and wait 5to10 min. and pressure wash it again 5)repeat 3rd) and 4th) steps again and again. 6)Buy 1 Gal. of Acetone and wipe off all the metal that will bee painted ! 7)repeat step 6) 8)Buy (1 quart)=4 spray cans of engine primer at you local auto parts store. 9)spray 1 coat and wait for 15 min and re-spray it again a 2nd coat. 10)buy (1quart)=4 spray can of your favorite engine enamel paint. 11)clean up all the mess! ![]() |
#14 |
cheap oven cleaner. about 4 cans.
scrape as much as you can first. then spray, let it sit for a minute, and scrub with a scotch brite pad wear gloves!!! and avoid rubber pressure wash off and repeat wipe with acetone rustoleum satin black in a quart and cut it with acetone spraying is the easiest and fastest
68 short fleet cst 71 custom deluxe lwb RIP (parts truck now) 71 Datsun 510 49 GMC 150 (waiting for me for the past 15 years) |
#15 |
2 words
STEAM CLEAN. |
#16 |
The Super Clean purple stuff works great, just don't get it on your hands. Use rubber gloves and a respirator. It's wicked stuff
#17 |
I bought gallons of degreaser , sprayed the engine bay all over, let it soak then pressure cleaned the heck out of it.
I cant find the picture of what it looked like before but here are a couple of picts of the after result.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#18 |
Tot Roddin'
Don't forget about the Detailing section of the board. Should be plenty of tips and tricks listed.
![]() Click me.... Do's/Don'ts of Engine Cleaning (Tell us your experiences...)
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-25-2010 at 09:48 PM. |
#19 |
ah yes, cant forget your section lol
im saving this link al, that looks so clean i could eat offa it
#20 |
thanks, it was well worth the effort here is a pict after it was painted....
#21 |
Tot Roddin'
Al did you go gloss on the inners and radiator support as well?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#22 |
So far I've used 6 cans of oven cleaner -- mostly on the crossmember and control arms. I've also used most of a gallon of the purple degreaser, a quart of por-15 marine clean, a half gallon of acetone, and a quart or so of paint thinner on various parts and places.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#23 |
![]() Join Date: Aug 2008
HOT water pressure washer- you don't need alot of pressure- the hot water is the ticket. Just an idea to throw out there- used to sell Hot Water Pressure Washers and water systems. We had to do so many "demos" on a monthly basis, so I was always looking for places to demo. If you find someplace that sells them in your area- call them up. You might have to listen to a sales pitch, but you might get it done for free.
I rented one for a day- Before and after pics. |
#24 | |
sorry about hi-jacking the thread...
#25 |
Wow, it looks great. It is encouraging to see. Makes me want to go out now and get started. Good job.
Thread Tools | |
Display Modes | |
