Old 01-26-2010, 12:45 PM   #1
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Brake Booster/Master Cylinder for 1-ton, disc conversion - Suggestions?
I'm looking for some product guidance here. There's brake master cylinder/booster assemblies available everywhere for 3/4 and 1/2 ton trucks, but not much found for 1-ton. I think clearance of tall valve covers limits me to stock/existing booster size.
I am looking for a complete assembly with proportioner.
Could you experienced folks point me towards one?
Truck details, to the best of my knowledge:
'70 Longhorn, 1-ton, single rear wheel
Bolt in disc conversion from another year Chev truck (4-wheel disc)
BBC 400, "Custom Camper 30"
Tall valve covers
Don't carry a camper or loads above 800lbs
The existing MC is partially visible in the pic. It's leaking like its made of swiss cheese. Don't want to rebuild; new ones aren't that expensive.
suprachrgd82 is offline   Reply With Quote
Old 01-26-2010, 01:27 PM   #2
Sub-versive
Boss Hogg
Sub-versive's Avatar
Re: Brake Booster/Master Cylinder for 1-ton, disc conversion - Suggestions?
Hydroboost.
Do a search, if I recall Yukon Jack had a good write up on it, maybe AJ too.
Sub-versive is offline   Reply With Quote
Old 01-26-2010, 02:19 PM   #3
CCCC
CCCC's Avatar
Someone on this forum has been producing and advertising booster/MC setups for sale, and I think they have the double diaphragm type you would want for the C30. They may also have the disc brake prop valve to sell along with the setup If not, you normally can find such a prop valve on here.
As for booster can size, I have seen two double diaphragm sizes - one is larger diameter and not as deep - the other is a smaller diameter can and a bit deeper. I was lookinf at a for sale booster from a guy on here and he did not seem to know if he had a DD type - so I posted some pics for him in his thread. You can see those pics by going to his sale thread - parts for a 1969 1 ton - in Phx/Mesa area - tkorinek is his screen name, I think.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 01-26-2010, 02:29 PM   #4
rcrahn
rcrahn's Avatar
Give a call to Power Brake Exchange in San Jose (408-292-1305) and talk with Michael the owner. I have bought many brake components from him. He knows his stuff and has fair prices. He will help you.
PS: PBE also has a place in Bell Gardens (562-806-6661)
rcrahn is offline   Reply With Quote
Old 01-26-2010, 05:18 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
whats wrong with the booster you have now?
All you need to do is locate a master cylinder for a 4 wheel disc vehicle, run the distsabution valve you have now, and if proportioning is needed, get an adjustable one and plumb it in line going to the rear.
Old 01-27-2010, 05:08 PM   #6
suprachrgd82
Farmtruck desciple
Great advise! Thanks, RCRCRAN and CCCC. Looks like I can loacte the right size, and maybe even keep it local. If you guys vouch for them, I'm in!
The one pictured above is a mess. Do I want to put in the time to make sure the diaphragm is undamaged by fluid and rebuild a grungy old MC? No, I do not. The brake lines are a hand bent mess from the PO. I'm looking for nice neat little coils and 90 degree bends in stainless.
A new one is inexpensive, clean, and easy to install.
Thread Tools
Display Modes
