02-04-2010, 07:16 PM | #1 |
It followed me home?
bagged w/stock arms, x-member, bed floor pics
I cant seem to get the suspension on my blazer the way I want and have come to the conclusion to bag it. I dont want to cut the floor, or spend the $$ on drop members or a-arms, steering issues ...
Does anyone have pictures of the truck/blazer with just drop spindles and bags, simple 4 link rear and stock floor? Everyone seems really concerned with laying frame and thats really all I find while searching for pictures. Thanks II did find this truck in the FAQ http://67-72chevytrucks.com/vboard/s...d.php?t=356469
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-04-2010 at 08:02 PM. |
02-04-2010, 07:54 PM | #2 |
Re: bagged w/stock arms, x-member, bed floor pics
X2
02-04-2010, 08:08 PM | #3 |
Wide n'Low
For what year Blazer?
My 70 is converted to 2wd with trailing arms and bags in the back, drop spindles and bags in the front. It actually sits a bit lower than this (need updated pics) as these tires are 295/50/15 on 8 inch Rallye with a modified Dana 60. In the front the stock shocks are a bit too long so it was holding the front up a bit.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
02-04-2010, 08:12 PM | #4 | |
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
02-04-2010, 08:22 PM | #5 |
67-72 parts collector,…
Adam,...
Ken's (n2trux) truck is probably the best example. Look at his pics. An Air Over Leaf set-up in the rear might be the best bet. |
02-04-2010, 09:50 PM | #6 |
Happy to be here
Thanks for the props Keith.
Adam take a look at what Travis is running-78 2wd Blazer BuildThat's a pretty simple set up for the rear of a Blazer. The front is all standard issue stuff. Use 3" spindles, bags and cups. You will need to build a custom bumpstop to allow it to roll when aired out.
02-04-2010, 11:12 PM | #7 | ||
If I read correctly he had it aired out in this picture, I think mine is lower than that now. I was thinking a 4-link might be the way to go and still gain a little traction over running leaf springs. EDIT: Yep, flip and shackles and the bags are for lift, pretty cool. I re-read the thread
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-04-2010 at 11:19 PM. |
02-04-2010, 11:59 PM | #8 |
That picture the front is sitting on the headers it looks like is why its not lower.
02-05-2010, 09:34 AM | #9 | ||
Happy to be here
My 82 Blazer had a "triangulated" four link. In my mind it was not the optimum set up. The rear liked to walk around due to minimal triangulation.
02-05-2010, 10:55 AM | #10 | |
In this picture here it looks like the bag might still be holding the rear up a little, I'm not sure if the axle is resting on the floor though. If it's not I would think a bracket like this, might be a better option? [IMG]http://www.*****************/files/imagecache/product/Behind_Axle_Lower.jpg[/IMG]
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-05-2010 at 10:56 AM. |
02-05-2010, 11:58 AM | #11 |
It'd be alot cooler if you did
Hmm... I told you so!!!!!!!!!!!!!!!!!!!!!!!!!!!
02-05-2010, 12:01 PM | #12 |
Low & Fast!
Adam here is a better pic of mine, with all the air out it will lay on the frame. I am thinking of changing it up with a 4 link and I would some good pics..
02-05-2010, 12:02 PM | #13 |
Low & Fast!
And some of the pics I found that I would like to do..
Here is a link this guy makes them and sells them for K5's http://cgi.ebay.com/ebaymotors/ws/eB...5370&viewitem= Trav
02-05-2010, 12:04 PM | #14 |
I know I know ha ha
Why are you changing it?
02-05-2010, 12:47 PM | #15 |
Happy to be here
Adam take a look at the bag mounts on my 82. I am pretty sure that's what you have pictured. If it were me I would go with that set up on the axle and used a tapered sleeve bag.
You could probably run that as an AOL and see if you like it. If not, go to a 4 link later.
02-05-2010, 04:51 PM | #16 |
Low & Fast!
I am going to put a small C in and try to get about 2" lower, plus the 4 link just looks cool and I sold my project truck so I need something to do. The way it is right now works just fine, so if you are looking for a cheep way that works well do the air over leaf. I was going to do like Ken's old setup, but I did not want to move one shock.
Hope that helps, Trav
02-05-2010, 07:44 PM | #17 |
Travis is the ride pretty bouncy withthat style bag in there? Seems like a sleeve bag would ride better.
02-05-2010, 08:42 PM | #18 | |
Low & Fast!
It did a little at first, then I found some stiff shocks and that fixed it. Now it rides like a log wagon.. Not that bad.
02-06-2010, 12:32 AM | #19 | ||
Thanks for all of your help guys, it seems like the more I read the more I confuse myself. There is a LOT of information on the net and seems like everyone has different opinions.
02-07-2010, 09:32 AM | #20 |
I think you are on the right track going with the four link from the beginning. You'll be happy you did. I would also encourage you to stick with a tapered sleeve bag out back.
You haven't mentioned air management. Got any ideas yet? |
02-07-2010, 09:47 AM | #21 | |
http://www.*****************/air-mana...minator-bags-5 Any suggestions?
02-07-2010, 11:41 AM | #22 |
Adam,...
Your "limiting factor" is the floor. Go out and look at your blazer now and see how close the center section of the rearend, is to the floor. That's all the lower you are going. I would c-notch it first. Then bolt on some 20's. Then get out a tape measure. Unless you pull the front inner fenders, (or modify them), you aren't going to go much lower. Plus air'd out,... the crossmember will hit the ground, if you pull the inner fenders. If you don't,... you'll have to run a bumpstop to keep the tires off the inners. That's kinda the problem with MY blazer. I wanted to not cut the floor, or remove the inner fenders. I actually drove my blazer lower, when I had my ralleys on it. Now that I have 20's and air ride,... sure it will set lower,... but my ride height is taller due to the 20's tire height. Remember, you still have to air up the front enough to get the alignment back. |
02-07-2010, 11:51 AM | #23 | |
As far as the front I'll probably either just pull the inner fenders temporarily and down the road I'll do some modification to them. If/when I bump up to 20"s a 245-40-20 is only abou 1/4" taller than the 15" tire than I'm running now so I really dont see too much worry there. I dont need this thing to lay frame so if the crossmember hits it will still be low enough for me but just in case it's not I've already got a buddy working on chopping a x-member for me like justpball did with his burb.
02-07-2010, 01:28 PM | #24 |
Happy to be here
Adam I agree that doing it once is the right way. The problem is it opens up a can of worms and you don't know where to stop.
Bolting on a rear 4 link isn't that big of a deal. What becomes an issue is how to mount a locater bar. A parallel for like has to have a 5th bar to keep the axle centered. It is usually in the form of a panhard bar, or watts link. That is where you will need to do your most research. As Keith mentioned your front is pretty simple. With 3" spindles, 2600 bogs mounted to short cups you can lay the crossmember with the liners removed or modded. That's going to get you pretty low. Anything lower will require a modded crossmember and removal or mods to the A/C system. I suggest you decide what your stopping point is before you jump in to it.
02-07-2010, 02:21 PM | #25 | |
this is thrtxschambers from the c10 board, if I can get my front as low as his and keep the rear level I'll be happy
Thread Tools | |
Display Modes | |
