haha, ford guys...
out with the quadrasuck in with the electrobogg.....
whose done it? do's?... dont's? i never hear much about this idea..... say i found an older camero 350 and wanted to put the fuel induction setup in my truck... possible? |
Re: Junk yard fuel injection
#3 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=317519
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
STILL PLAYS WITH TRUX
Hold on there it all depends if hes talking about TBI OR TPI.
#5 | |
//RF
haha, ford guys...
thanks guys, this is all very interesting to me...VSS? whats that?
also, im worried that off the loaner truck, i will come across too many wiring ghosts...??? |
#7 | ||
If you can get the entire harness from a 88-91 square body truck, blazer, or 'burb you could swap the whole thing. The 88-89's have a non electronic speedo that have an optical sensor that works as a VSS (and should work with your current transmission), and the 90-91's have electronic speedo. so get the cluster too if you can. Quote:
But, what are your thoughts about running an aluminum 4 barrel intake with TBI? You would loose the EGR, correct? Will it adversly effect the fuel mileage? The reason I ask is I have the complete TBI set up from a '89 'burb (including the wiring harness and speedo with the optics attached to it) and would like to put it on my '82 CCSB (GM Goodwrench crate 350 with 2 piece rear main) for reliability and fuel mileage. It currently has an Edelbrock intake (not sure which one) and Holley 4160 600cfm carb, so just buying an adapter plate would be super easy, but is it worth it to swap over the TBI intake? Thanks for all your input RF!!
![]() ![]() Last edited by joe231; 02-05-2010 at 11:27 PM. |
haha, ford guys...
would the speed sensor be necessary? wouldnt without it just create a rich condition at high rpm's?? im fine with rich!! haha
JMO I have TBI on my 92 Z71 and I hate it, no power. I have thought more than once about swapping to Vortec heads and 600 Holley. For around $1800.00 you can go with an aftermarket TBI that looks like a Holley double pumper doesnt have to have a return line, can handle up to 4 or 500 hp and is self learning, heard lots of folks brag on them. The factory TBI is not performance friendly. Thats just me they are reliable, but that about the only nice thing I can think of.
#11 | |
#12 | |
To those who say that TBI has no power - it is true for engines equipped with OE camshafts and factory ECM calibrations. Back in the day GM put peanut cams into LO3 and LO5 engines which by 3500RPM were done for all practical purposes. Over the years I have seen how well TBI responds to a mild RV camshaft and minor head work. Add a good flowing exhaust and you have an engine that will easily deliver low end torque and decent high RPM HP performance. The trick is to have ECM delivering enough fuel and timing both which can be accomplished. Stock SBC TB flows 490 CFM which is more than adequate for 98% of all driving that a typical street (dd) engine will see. The problem is usually inadequate fuel pressure. Factory calls for 9-13 psi range which is a very wide range - I like to see 14 to 16 PSI (and updated VE tables) as this makes for better performing engine. If your 4-bbl intake does not have EGR provisions you'll have to program EPROM to disable EGR function - or other wise SES will be set - this will adversely affect driveability. Depending who you talk to EGR improves highway mileage by about .5 to 1.5 MPG. //RF
#13 |
check out painless wiring they have a vss that goes inline with speedo cable. The extra long harness alowed me to mount everything under the seat very neatly. I used GMs vortec tbi intake from summit with vortec heads. Good power, economy,very reliable
#14 | ||
I believe the link I posted earlier burns custom chips, guess I'll have to look further....
#15 |
OutOfMyMind & I'llNeverKnowWhy
After having TBI on the 92 Firebird, I must say I am not impressed by it at all. I'd much rather have carb like my 86 Firebird or TPI injection.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
#16 | |
One day...
![]() Last edited by scotts62; 02-06-2010 at 06:00 PM. |
#17 |
does anyone read anymore
![]() ![]() Last edited by joe231; 02-06-2010 at 03:20 PM. |
#18 | |
The weakest link in a TBI equipped engines is not fuel injection part but a puny camshaft, some what restrictive heads and chocking exhaust system. Stock TBI cam at .050" lift is 179/194 deg (I/E) and maximum lift with 1.5:1 rocker ratio is 0.350/0.384 (I/E). It is outright pathetic, If you stick carb or even TPI on top of a TBI short block (with that cam) you will loose both torque and HP and end up with a bigger dog! I have seen several of these attempts at TBI to carb conversion fail miserably (half had other problems, but this is a family forum so I will keep it clean!) The key to performance (we are talking solid dd, not a fire breathing monster) TBI is take advantage of what is readily available to any Joe: mild camshaft (keep it middle of the page: LSA 112deg, lift at about 0.425 to 0.475, duration 195-205deg @ 0.050) reworked heads (springs, mild port cleanup) exhaust system (headers, cat after exhaust) low restriction intake ECM tuning and optimization. The key advantage of TBI over TPI is that it is relatively low cost and readily available just about anywhere. I have to admit that I am regular JY visitor and many month go by when before I see a wrecked TPI camaro. Whereas TBI cars or trucks are there all the time. //RF
#19 |
BAD BOW-Silverado XST
A LS1 conversion is hard to beat.
http://www.hotrodlane.cc/77chevytruck/77chevy.htm |
#20 | |
78 C-10 5.3 LSX -4L60E Last edited by 78-5.3; 02-07-2010 at 09:57 AM. |
#21 | |
Still plays with trucks
I retrofit my 90 Z71 TBI 350 with a vortec truck roller cam setup I got at the wrecking yard and it made a huge difference in power. Cost me less than $200 to do including the complete gasket set for the engine and a hydraulic roller style timing set and the cam, lifters and spider retainer setup & pushrods.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#22 | |
True there is less maintenance and its low cost (not counting my fuel pump in the tank that goes out every 6 years and you have to drop the whole back end to get to the tank lol)
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! Last edited by Justins76; 02-07-2010 at 08:29 PM. |
#23 |
do the 5.3 6.0 swap I just finish mine... more power just my .02... did my junk yard special swap and well under 1900 all finish. can beat the just over 300hp with the 22+mpg...a/c and cruise control
#24 |
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w ![]() Last edited by SatisTraction; 02-09-2010 at 11:39 PM. |
#25 |
A stock TPI system is pretty limited too and falls on its face around 4500 rpm. They just don't flow much air stock.
The parts to make it much better are out there but add up to a mountain of money in a hurry. Most TPI guys end up with a Holley short runner MPFI system that looks like the LT1 intake. If you don't have to meet emissions that is the way to go to keep your old engine but for the same cost you can do an LS engine swap now and get more HP and MPG out of the deal.
Thread Tools | |
Display Modes | |
