Old 02-08-2010, 09:58 PM   #1
Desertryder
Desertryder's Avatar
I need help w/ Edelbrock 1405
My '76 GMC K15 came with an Edelbrock 1405 Performer Series carb when I
bought it. I am in the process of rebuilding it and would like to put an electric
choke on it. ( It currently has the manual set-up ) My problem is those chokes
are really expensive! Is it possible to use one off a junkyard 1405 or maybe
one from another make carb.? I guess I'm cheap cause 50-80 bucks seems
off the hook to me. Any suggestions?
Desertryder is offline   Reply With Quote
Old 02-09-2010, 01:21 AM   #2
ToughBowtieTruck
Re: I need help w/ Edelbrock 1405
From what I have seen, all the square bore Edelbrocks use the same electric choke. 1405 and 1406, both of which I have, have the mounts for the electric setup on them.
Personally, I hate the electric choke. Never worked right for me.
-Josh
"Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division
"Yeah, they're called Congress!!" -Homer Simpson
ToughBowtieTruck is offline   Reply With Quote
Old 02-09-2010, 10:46 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
X2, I run and very much prefer manual chokes on all my carbs.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-09-2010, 02:28 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
The trick with the electric chokes is to get them adjusted right. Over the years, I have managed to get mine to the point that they work just fine. The one on my Son's truck was the worst and it took some playing to make it work. You can put a choke on that carb from a used carb---but it would work best if it was the same design carb as what you are working on.
That being stated, the Edelbrock 1405, 1406, 1407, 1411 carbs are the same body parts----ALSO the AFB carbs that Carter Carbs sells is the SAME EXACT unit, just different retailer's name. The Edelbrock and Carter AFB carbs are ALL made by a company called Magnetti-Marelli USA and sold under the AFB name. The parts are interchangeable and the part numbers are even close to each other. I have a Carter in my storage that is full of Edelbrock parts, because Edelbrock sold them cheaper than Carter did.
Frank
piecesparts is offline   Reply With Quote
Old 02-10-2010, 02:16 AM   #5
wedgemon
wedgemon's Avatar
Cool Re: I need help w/ Edelbrock 1405
The kit is $48.75 at summit. #1478. Someone's banking at 80 buck$. And they're easy to install.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Thread Tools
Display Modes
