Old 02-08-2010, 11:10 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
How many are using stock gauges?
How accurate are these things? I dont really want to install aftermarket gauges under my heater controls, or cut them into my new bezel. I dont care about the ammeter, but I feel weary since it dosent tell me exactly how hot the motor is or how many psi the oil is running at.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 02-09-2010, 01:14 AM   #2
red71c10
The Red Menace
red71c10's Avatar
Re: How many are using stock gauges?
I've heard originals aren't very accurate, but that's what I'm using. They do make aftermarket gauges that will fit right in the stock dash. I've seen both digital and analog available. Search the site and you will probably find some examples of what members have done.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 02-09-2010, 01:41 AM   #3
BIGBLU 72
BIGBLU 72's Avatar
im running the factory gauges including tach in my GMC. i feel like they are pretty accurate (except speedo b/c of the tires/lift)
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 02-09-2010, 01:45 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good question. Mine are all stock, and chances are that good aftermarket gauges may be more accurate. But mine work, and at least let me know that things I have oil pressure and I'm not overheating....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-09-2010, 02:11 AM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
I installed aftermarket oil and water gauges into a stock cluster for the reasons you mentioned... I just wasn't comfortable with the "vague" readings you get from the stock gauges. Here is how mine turned out.
http://67-72chevytrucks.com/vboard/s...d.php?t=382886
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 02-09-2010, 09:24 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
I am running stock gauges in my '71 C-10, they are accurate for what I want since it is just used most of the time as a farm truck.
My '67 is bare bones and has no gages, so I went the easy way for now and put in a set of three gauges under the dash. I used these gauges so I could drive the truck for a while so I could figure out which way I want to go on a restoration.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-09-2010, 10:43 AM   #7
70cst
70cst's Avatar
I would think if the guages and associated hardware were in good shape they would be ok...they work well 40 years ago so if they are in similiar condition one should be good to go...then again what do I know
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-09-2010, 12:37 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
I had stock gauges in a '72, I actually prefer the aftermarket gauges in my '69.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-09-2010, 12:54 PM   #9
Nova70
Nova70's Avatar
I don't care for the stock gauges... Mine bounce around and the speedo is off by about 11mph. The battery indicator is the worst for me. Being an audio system nut, that meter doesn't tell me exact voltage which drives me nuts. I have since installed an aftermarket voltage meter in a different spot. I'm hoping to buy the Dakota Digital cluster this summer.
Nova70 is offline   Reply With Quote
Old 02-09-2010, 01:04 PM   #10
junkyardjohn
junkyardjohn's Avatar
Stock gauges are o-k. But my trucks are nowhere near stock & i have alot of money tied up in my motor & tranny, & like to accuritely know what the vitals are & whats happening. Case in point.. I've not destroyed an atuomatic tranyy. Since i started using tran.s temp gauges 20 years ago. To each his own... But remember.. Those gauges were made 40 sum years ago & by the lowest bidder. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 02-09-2010, 04:05 PM   #11
drivethechevy
drivethechevy's Avatar
ive never had a problem with the factory gauges, my dad and grandfather have never had any problems with them being inacurate, my grandpa has owned a 69 since new and owned many others.
now if you are looking for a gauge that gives you numbers to go by you are gonna have to go aftermarket, there are alot of different ways you can customize gauges without wrecking the bezel, i ad sun super tach's to my gauge clusters and i have replace factory gauges with better aftermarket and used the vacuum gauge hole to add vacuum gauges to clusters not equiped, if you do it right it looks pretty good
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 02-09-2010, 04:39 PM   #12
big_al_71
big_al_71's Avatar
I have the factory ones and they work ok....but I am going with Autometers because they will be 100% more accurate and look alot better...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-09-2010, 05:11 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
My truck only came with dummy lights, so I added these:
I finally got a GPS unit and was able to test my odometer/speedometer. The odometer is very very close to being accurate and the speedometer is dead on for low speeds and only a couple mph "slow" on the higher speeds. That's crazy conisdering I installed a 7ooR in my truck. Fuel gauge has and always will suck, it will never be "accurate" unless you install baffles in the tank to prevent fuel sloshing.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-09-2010, 05:20 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If the stock guages are in good working order then I see no reason to change.They do not have the markings to tell you the degree or volts/amps but if you know the engine is running at the proper temp and the guage always reads the same you should be fine.Same applies for any of them.I have had vehicles that didn't read accurately but always read the same so I knew everything was normal.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-09-2010, 08:40 PM   #15
57larry
I run 3 under the dash
57larry is offline   Reply With Quote
Old 02-10-2010, 12:28 AM   #16
powell72
powell72's Avatar
I can tell you the factory oil pressure gauge is a 60 psi gauge, so the marks go 0-15-30-45-60.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 02-10-2010, 12:39 AM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: How many are using stock gauges?
^ Good info to know... thanks!
- Mike -
RIP El Jay
Old 02-10-2010, 12:47 AM   #18
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I run the factory gauges. I don't think my Amp gauge has ever worked right but I don't need it. According to the law my speedo is correct. My temperature and oil pressure gauges have always functioned correctly. I've owned the truck 20 years and have about 245000 on it.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 02-10-2010, 09:09 AM   #19
mrein3
mrein3's Avatar
A couple of superbowls ago I made out so I decided to use that windfall on a tach cluster. Right about then there were a lot of posts about how inaccurate the stock tach is. I had just installed a fresh 383 and had an aftermarket tach laying around that I used for break in so I decided to place that in my used tach cluster. I also installed an 80s clock at that time.
Today - if I ever have the time to work on it - I would eliminate the clock and place my trans temp gauge in that hole. Then I'd eliminate the amp meter and install a volt meter like C10-Driver did with his temp.
I know for a fact my stock temp and oil pressure gauges work so they are staying.
When I first put together my current cluster I used a wood grain stock piece. Later I switched to a black one but could use a shiny new re-pop one.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Thread Tools
Display Modes
