Old 02-10-2010, 11:20 AM   #1
ricks71pu
ricks71pu's Avatar
newer rims?
Say, does anyone know what newer style rims will fit safely on my 71 GMC? looking at adding '96 stock GMC rims. Mine are 6 lug, and the truck is the GMC version Longhorn. Wondering about clearence, etc.
thanks,
ricks71pu is offline   Reply With Quote
Old 02-10-2010, 01:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: newer rims?
a longhorn with 6 lug rims?
Do you have any photos of it, or maybe post the VIN?
Old 02-10-2010, 03:39 PM   #3
michael bustamante
michael bustamante's Avatar
Re: newer rims?
I thought a 71 GMc would be a 5 lug? If it is a 6 lug then the `96 rim hub clearance shouldnt be an issue. I dont know about backspace though
1967custom
michael bustamante is offline   Reply With Quote
Old 02-10-2010, 03:57 PM   #4
ricks71pu
ricks71pu's Avatar
Re: newer rims?
wow, thanks for the replies so quickly. i will take pics of truck and glove box info. it definatley is a 71 and 6 lug vehicle. actually a nice truck with factory tach even!
-Rick.
Old 02-10-2010, 04:00 PM   #5
epashhans
epashhans's Avatar
Re: newer rims?
I ran into the hub clearance issue from the newer rims, at least after market. Its a smaller diameter. I got by it with a 1/2 spacer on the front with longer lugs. On the back I got a larger spacer which not only fixed the hub size issue but also spaced it out correctly for the offset. There are a couple threads on here about modern rims, but I can't really help you beyond that.
Check these out, you might find some helpful info;
http://67-72chevytrucks.com/vboard/s...d.php?t=371387
http://67-72chevytrucks.com/vboard/s...d.php?t=363031
My truck is the black one...gives you an idea how it looks with the spacing corrected. I would have like a little wider rear spacers...but not much.
http://67-72chevytrucks.com/vboard/s...=361157&page=3
PM me if you have any questions or needs some pics. Good luck!
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 02-10-2010, 04:32 PM   #6
bsm78
Re: newer rims?
i wonder if the new style wheels will fit. i got a set for my 01 yukon and their 17s with 6 lugs. if so those would prob look good.
bsm78 is offline   Reply With Quote
Old 02-10-2010, 06:31 PM   #7
OARNGESI
OARNGESI's Avatar
Re: newer rims?
Aint longhorns 3/4 ton
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-13-2010, 10:03 PM   #8
grs
Re: newer rims?
These came off of my 69 C10. Just an idea. They are 6lug. Not trying to sell them. You are to far away.
grs is offline   Reply With Quote
Old 02-14-2010, 12:25 AM   #9
Longhorn Man
Re: newer rims?
all longhorns were 3/4 ton or one ton... they were all 8 lug from the factory... unless yours has had a 1/2 ton suspention swapped in.
Old 02-14-2010, 03:20 PM   #10
ricks71pu
ricks71pu's Avatar
Re: newer rims?
My bad. mine s an 8 lug truck.still, suggestions, comments?
Thread Tools
Display Modes
