Old 02-17-2010, 12:24 PM   #1
T/C
T/C's Avatar
Rear window swap And front window seal
Okay already have a solid rear window i want to put in... And i have a used rear window seal... and have a few questions on that...
First off how do i get the window out... i was told its as simple as pushing it out... But i can tell you its not that simple from me siting out there trying looking dumb lol...
Second should i get a new seal or will a old one work? I am going from sliding to solid....
Last question is on the front window... My drip rails have a leak and i am going to be re sealing them... but the water got in between the window and the seal and rotted some of it out.. So i am going to get a new seal what all will i need to do and how do i do a front window? I have never done it before and dont want to mess anything up.
Thanks!
T/C is offline   Reply With Quote
Old 02-17-2010, 01:29 PM   #2
weircc
weircc's Avatar
Re: Rear window swap And front window seal
change them both they are cheap i would recommend the precision (i think this is the brand been awhile) gasket they are top of the line as for installation. I will also say this if you haven't installed the front glass on one of our trucks i would seek a professional cause they are one of the hardest to install
weircc is offline   Reply With Quote
Old 02-17-2010, 01:58 PM   #3
T/C
T/C's Avatar
Alright cool i will look it up and okay i will find someone to do it Lol i dont want to screw anything up..
Old 02-17-2010, 02:10 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always do my own windshields. You have to lube the seal very thoroughly and work the lip over the pinch weld with a pointed tool. It's not for the faint of heart though because you will be doing some serious pushing and thumping of the glass with your hands.
I did one about a week ago and had my girlfriend help me. As I was in the cab working the seal into place she was outside applying pressure where I needed.
Back windows are tempered glass and are very easy. For them I use the old weedeater string method. You can hardly break a back window. To remove them I lay in the cab and use my feet to push in the corner real hard and they will push out. Don't worry about it, they are very tough. I've hit a lot of them with a fire axe, trying to break them, but it bounces off a lot of times.
Old 02-17-2010, 02:11 PM   #5
Trip59
Who needs sleep...
Trip59's Avatar
Ok, so installing the window is PITA, but what about fixing the rust/rot? I'm asking because this is on my short list too...though I'll be the dumbass sitting out there trying to put it IN by myself
Trip
Trip59 is offline   Reply With Quote
Old 02-17-2010, 02:16 PM   #6
Tx Firefighter
I'm a weld and grind kind of guy when it comes to fixing rust out. If I can't get a patch off of a parts truck I make one from scratch. I'm not familiar with any patch panels for windshield lip area.
Old 02-17-2010, 02:36 PM   #7
T/C
T/C's Avatar
Trip
Yeah i am worried about rust in the window too... i think the corner may have a little...
Old 02-17-2010, 02:37 PM   #8
T/C
T/C's Avatar
Thanks for the tips Tx
Thread Tools
Display Modes
