Old 01-31-2003, 08:03 PM   #1
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Bought me some Electric Fans
Found a set of Intrepid Fans at my buddies Salvage yard....so whoever it was that got them free got a hell of a deal. Its still costing me 100 bucks but I think its worth that. Should be able to mount them up on Sat. or Sunday.
Yay!!
No more ugly fan shroud or fan blade!! hahaah
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-31-2003, 08:04 PM   #2
LOHRTBT
LOHRTBT's Avatar
now.....anyone wanna buy a brand new upper fan shroud?? haha The lower is not new but just fine.
~Dave~
Old 01-31-2003, 08:49 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Way to go Dave. Where you getting the relays, and thermostats, etc. If they work good, you will love them. I sure love my Spal's. It is so nice to get rid of the shroud and clutch fan.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-31-2003, 09:00 PM   #4
LOHRTBT
LOHRTBT's Avatar
not sure...prolly just at O'reillys or at Parr automotive. Im trying to decide if I want them on a switch or on a thermostat. The only thing about the switch that scares me is if I leave it on...but i dont think that would happen since I would hear it.
If I do the thermostat...how hard are they to install?
What will I need the relays for??
Edumacate me on this.
~Dave~
Old 01-31-2003, 09:57 PM   #5
scarface-87
these are on ebay, are these the ones that will work, just wondering, i might go hunting for some tomorrow
http://cgi.ebay.com/ebaymotors/ws/eB...category=33600
Danny
http://dg721.tripod.com
87 swb c10
scarface-87 is offline   Reply With Quote
Old 01-31-2003, 11:17 PM   #6
bigd65
bigd65's Avatar
get the hayden harness at O'RIELYS, they have been working flawlessly for aout 2 years. oh BTW, i am the one that got them free from my buddy that owns a wrecking yard
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 02-01-2003, 12:40 AM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Jeff he have any more down there ?? TIme to hook us up
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-01-2003, 01:41 AM   #8
bill_ont_canada
Nobody is perfect...
bill_ont_canada's Avatar
I also would like to learn about installing elec fans.
If the engine is not turnin the fan that should give a little more power shouldn't it ???
Have a fabulous day.
Bill... (ö¿ö)
" Loud Pipes Save Lives "
bill_ont_canada is offline   Reply With Quote
Old 02-01-2003, 02:41 PM   #9
PHOENIX
Yes and no. Alternator create the power for the fan. The more power that is sucked from an alternator the more drag it puts on an engine. So you may not have fan blades draggin the engine down, now you just have the alt. draggin the engine down. The alt. doesnt drag as much, but with the electric fan I can notice some engine rpm loss when the fan turns on. You can get a idle compensator to solve this though, like an AC system would use. The plus side is, the fans are way more efficient (?) and only use power when they need it. I have mine on a toggle so I can control it and overide it. I like it that way, except every once in awhile I forget to turn it on in drivethrough. I need a little light to turn on at a certain temp to let me know. Can someone help me with that? But yes an electric fan does rob some engine power, but not as much as a regular fan, and it only robs power when it needs to, not all the time. Its a major plus and everyone should do the conversion.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 02-01-2003, 08:23 PM   #10
GMC Jim
GMC Jim's Avatar
My Thoughts on engine cooling------------
--- A clean, undamged 4-core radiator
--- Coolant return system with a 2 quart or larger reservoir
--- Proper operating radiator pressure cap and
thermostat
--- Close fitting fan shroud which captures the entire radiator
core area
--- Using a properly operating fan clutch and matching fan. This
type of fan does not draw engine horsepower at highway
speeds and only when the radiator airflow temperature
requires the fan to " kick-in"
--- Fan location will have half the thickness of blades inside the
shroud, the other half just rearward.
--------An aftermarket electric fan to cool an auxillary engine oil
cooler or a transmision cooler might be desirable...
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 02-01-2003, 08:36 PM   #11
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up
Dave,
The main reason for a relay is to have the relays coil handle the power loads the fan draws and not to cause an overload on the main fuse block or worse yet a fire.
Never connect a ele. fan direct to your fuse block with out a relay.
I pulled the entire relay system for an ele. fan set up out of a 90's chevy corsica and then installed it in my truck and the relay clips into a nifty base so if it go's bad i just have to pull it out and plug in a new one no rewireing required.
I also hooked up a thermister in the coil power supply so that when the temp hits 180* it closes and the relay's coil is activated and the fan turns on and any time you are at cruise the fan isn't running due to the increase of air flow and that way you never have to worry about forgeting when to turn it off or on.
Hope that is a clear explanation and that i didn't confuse you even more
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-02-2003, 02:46 AM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Relay wiring help.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Thread Tools
Display Modes
