Old 02-22-2010, 11:51 PM   #1
lyrikz
PITbut
lyrikz's Avatar
1 step forward, 2 steps back....
A few weekends ago i finally got my truck running. My lower radiator hose had a sharp bend to it so i took it off, trimmed it and reinstalled it. I then added coolant and watched as the coolant poured out of the middle of the radiator. So my brand new 4 core radiator i some how put a hole in it. SOO, i pull the radiator and go and put my new radiator in. Its an identical radiator but i installed my rubber bushings on the bottom this time. ( i had left them off last time. Bad, i know.)
NOW, the radiator sits .5" to high....The radiator isnt a stock replacement for my vehicle. It sits about .5" to high. I took care of that by not having the rubber mounts in the bottom. But, i realize i cant do that because it will just rub right through the radiator if its metal on metal. I cant use my mounts and honestly i am not good at coming up with ideas. I just need two upper radiator supports that will mount in the stock location. Any suggestions? Tips? Materials? I dont need it super fancy. Stock worked fine.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-23-2010, 12:14 AM   #2
Ackattack
Ackattack's Avatar
Re: 1 step forward, 2 steps back....
Sounds like my radiator. I believe mine may actually be for a 73+. It is aluminum with plastic side tanks.
I don't know if you can tell in this picture, but I used a stack of washers and longer bolts to hold the upper supports in place for now.
Ackattack is offline   Reply With Quote
Old 02-23-2010, 12:15 AM   #3
grs
I put a desert cooler radiator in my 69. It was a little bigger. I trimmed the rubber supports a little. I got it to work. You could use an old inner tube. Cut and make your own pieces.
grs is offline   Reply With Quote
Old 02-23-2010, 12:26 AM   #4
lyrikz
PITbut
lyrikz's Avatar
I was thinking of the washer. I was actually contemplating using a plate with the holes in it. That looks like my radiator. I have electric pusher fans. Mines plastic with aluminum core. The one i jabbed a hole in was brass... This one is a ton lighter and i guess the aluminum cools better??
and sold.
Old 02-23-2010, 08:42 AM   #5
mrein3
mrein3's Avatar
I ran into the EXACT same thing when I put in a 4-row radiator into my 4x4. I bought all new aftermarket cushions, drilled out the old bottom mounts and moved them over, and ended up with it sitting too high. I simply made a little plate out of sheet metal and bolted one end to the shroud and one end to the top bracket. See picture. It has been this way for a couple of years.
I posted questions in this forum about it. The general consensus was if you go with the new cushions everything sits up too high.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is online now   Reply With Quote
Old 02-23-2010, 10:20 AM   #6
fishingjred73
fishingjred73's Avatar
Check out how these were raised. 2nd post down
http://louisianaclassictruckclub.fre...-t1016-60.html
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 02-23-2010, 10:50 AM   #7
lyrikz
PITbut
lyrikz's Avatar
I dont have a fan shroud, so thats not really an issue.. Its just where it mounts to the core support. Im sure i will figure it out, just i know you guys have some AWESOME ideas.
and sold.
Old 02-23-2010, 10:59 AM   #8
QKENUF4U
QKENUF4U's Avatar
just get some 1/2" spacers w/ longer bolts and be done....
QKENUF4U is offline   Reply With Quote
Old 02-23-2010, 11:51 AM   #9
lyrikz
PITbut
lyrikz's Avatar
I was thinking to put a solid piece of metal instead of a spacer. Then grind it down to match the form of the actual bracket... Think that should work.. probably use a piece of aluminum or something. not sure.
and sold.
Old 02-23-2010, 12:00 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
How about having your brass radiator fixed? Ask around at some of the auto repair shops and see if they know of someone that fixes them. I have fixed three or four of them and depending on where the hole is they can be pretty easy to fix.
LockDoc
Leon
Old 02-23-2010, 02:15 PM   #11
lyrikz
PITbut
lyrikz's Avatar
LockDoc
I have a shop that fixes the radiators. But the place i bought mine from actually let me warranty this radiator.. It was bought in oct 08 and i TOLD her that i think i knicked a fin and its leaking. She didnt want me to repair is to she just sent me a new one. Awesome place to buy stuff.. Would of been a 30-40 dollar fix on the old one, but i kinda like the aluminum better.
and sold.
Old 02-23-2010, 03:00 PM   #12
Mike J
vw guy & now c-10 guy
Mike J's Avatar
I had the same problem- I ended up using the 4-core brackets and rubbers at the bottom- but just went and bought some metal strips at Lowe's and drilled them so i could use the factory holes in the core support and then bent the other end 90 degrees to hold the radiator in place- nice and simple and only cost like 6 bucks- works for me.
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-23-2010, 08:13 PM   #13
fishingjred73
That's what was done here^^^^^^^^^^^^^^
James
Member of
Old 02-23-2010, 08:28 PM   #14
Shane
Shane's Avatar
Do what he said. You're over-thinking this thing.
Shane is offline   Reply With Quote
Thread Tools
Display Modes
