Old 02-23-2010, 01:16 PM   #1
crakarjax
crakarjax's Avatar
Super low-buck compressor - $19
Don't hate me. I am going to buy a compressor with capabilities equivalent to the 400c. It is on sale for $19.
Linky
I'll run the crap out of it before I install it for self-assurance. Comes with a 1-year warranty. No mention of whether it can be mounted on it's side... I guess I'll just run it laying on it's side.
Quick specs: Over 33% duty cycle @ 100PSI, pull less amps than the 400c as it comes with a 15amp fuse and 18AWG wire lead. May need to be modded to remove the guauge(or not) and accept DOT line.
Let the flaming begin!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-23-2010, 02:01 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Super low-buck compressor - $19
If it takes "under" 3 1/2 minutes to inflate a car tire (typically 35-45 psi), how long is it going to take this thing to fill a 5 gallon tank to 175 psi?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-23-2010, 02:08 PM   #3
71swb4x4
71swb4x4's Avatar
You get what you pay for. I wouldn't treat this as anything more than a science experiment. The main question being, how long before the compressor goes south? Will it leave you stranded somewhere? Will it last five years and make the skeptical people eat their words?
Hard to say on any of that, but I am putting my money on you being disappointed. The price is part of the battle. Now you need to figure out how to mount it, and get the proper lines run to it. That's additional time and money, that may all be a waste when this thing burns up from being run too hard.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-23-2010, 02:17 PM   #4
lyrikz
PITbut
lyrikz's Avatar
Linky
Neat experiment. But i can tell you it wont work. Going to take forever to fill up a 150 psi in your tank, IF it can get it to that level. Keep us updated though, JUST in case...
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-23-2010, 02:25 PM   #5
crakarjax
crakarjax's Avatar
The viair 450c "Airs up a 35" tire from 15 to 30 psi in less than 3 minutes."
It is a science experiment... I like this kind of stuff, that's why I became an engineer in the first place . I will definately design my system to roll when aired out. No strandedness here.
Old 02-23-2010, 02:59 PM   #6
Shane
Shane's Avatar
Just curious as to what kind of engineering degree you hold? M.E.? E.E.? C.E.? P.E.? I.E.?
Shane is offline   Reply With Quote
Old 02-23-2010, 04:18 PM   #7
Chevydude56
Chevydude56's Avatar
Having no experience with air suspension in car/light truck I was also wondering if one of these could be used. I would like to bag my 'burb low buck.
For $19 I would buy one and experiment with it .
keep us posted
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 02-23-2010, 05:13 PM   #8
dv8customs
dv8customs's Avatar
It says it is a 100psi compressor and if that is all it will do then it isn't worth using. 100psi of air isn't going to last you very long in a 5 gallon tank. You will have to fill the tanks twice to lift all the way up. No way that thing is going to run a tank up to 175psi.
Good to see a fellow engineer though. I am an M.E.
dv8customs is offline   Reply With Quote
Old 02-23-2010, 05:32 PM   #9
crakarjax
crakarjax's Avatar
EE. The viair 400c is "33% duty cycle @ 100 psi with a maximum working pressure of 150 psi". I did read the specs, you know! Like I said, it seems like an experiment worth trying. Worst case, I'm out $20. Best case, it works.
How long do viair compressors typically last before failure?
Old 02-23-2010, 05:43 PM   #10
1sikchicksc10
Chicks build stuff too!
1sikchicksc10's Avatar
I've had my vi-air's for 5+ years.. never ANY problems..
Christina
Petitioning Nor*Cal NO REGRETS
www.myspace.com/baggedc10
Projects:
1979 GMC High Sierra C10- Bodydropped on 24's
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=387546
1965 Cadillac CoupeDeVille- Bagged on 22's
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=387548
1sikchicksc10 is offline   Reply With Quote
Old 02-23-2010, 05:48 PM   #11
dv8customs
dv8customs's Avatar
Apparently you did not read the specs for the Harbor Freight unit. The user manual clearly states in the table at the beginning and in section 5 of the operating instructions that the maximum operating pressure of the compressor is 100psi.
Old 02-23-2010, 05:58 PM   #12
Shane
Shane's Avatar
How does one perform a true comparison of a $20 harbor freight compressor to a $185 Viair 400C.
Old 02-23-2010, 06:20 PM   #13
dv8customs
dv8customs's Avatar
You can't. The HB unit is intended to ocassionaly air up a basketball or a flat tire. It will not hold up to the stresses of maintaining an air ride system as that is not what it is designed to do.
Old 02-23-2010, 06:22 PM   #14
1sikchicksc10
100%
Christina
Projects:
Old 02-23-2010, 06:27 PM   #15
royo
royo's Avatar
Linky
Good luck with it. I hope it works for you. let me know thx
nickle and dime
royo is offline   Reply With Quote
Old 02-23-2010, 07:01 PM   #16
crakarjax
crakarjax's Avatar
I did read it, and I know that. Fact of the matter is, the way I read it the viair operates at 100PSI, which happens to be the max pressure of the HF compressor, which also operates at said pressure.
I think you are confusing PSI with CFM anyway.
Old 02-23-2010, 07:07 PM   #17
tubbedII
needs more $$$
tubbedII's Avatar
I like the idea, and who can beat $20 for a comp. You say you're gonna test it before really using it, what's the plans?
1970 2wd Blazer
Old 02-23-2010, 07:11 PM   #18
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Bunch of haters.....
I have that same compressor on a 20 gallon tank. Fills it to 200 psi in under a minute.
AVS_JASON is offline   Reply With Quote
Old 02-23-2010, 07:22 PM   #19
dv8customs
dv8customs's Avatar
No confusion here. The Viair unit, according to you, has a max operating psi of 150. That means you can fill your tank to 150psi. The HF unit has a max operating pressure of 100psi, that means you can only fill your tank to 100psi.
Old 02-23-2010, 07:23 PM   #20
crakarjax
crakarjax's Avatar
I'm going to lay it on its side and let it fill my 60gal tank to 100PSI. In fact, I might use it exclusively to fill my air tank for a while, as long as I'm just using the ratchet. If it can fill my 60gal to 100PSI in under 12 minutes(max run time, continuous) I'll be impressed.
I am going to make note of the PSI at 12 minutes and from there determine the max tank size that it will fill to 100PSI in 12 minutes.
I have an IR thermometer, so I will let it run for the recommended max of 12 minutes and see how hot it gets. Then I'll run it some more to see at what rate the heat accumulates.
One concern of mine is that it may be overly loud. How loud in sones is the viair 400c?
Old 02-23-2010, 07:33 PM   #21
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
That thing only has 0.88 CFM
Old 02-23-2010, 07:37 PM   #22
dv8customs
dv8customs's Avatar
And it doesn't say at what pressure it is flowing that .88CFM. I would bet that it is .88CFM at zero head pressure because that will be the max amount. For comparison the Viair is running .85CFm at 140psi
It will never make it
Old 02-23-2010, 07:39 PM   #23
cajundragger
^^so if the 60 gallon tank was at perfect vacuum and the compressor pumped it up to atmospheric pressure, it'd take 9 minutes. lol. dont think your going to meet your 12 minute goal.
cajundragger is offline   Reply With Quote
Old 02-23-2010, 08:10 PM   #24
1sikchicksc10
I cannot stop laughing.
Christina
Projects:
Old 02-23-2010, 08:23 PM   #25
Shane
Shane's Avatar
You should just go throw a twenty in the toilet and grab the flush handle.
The results are going to be eerily similiar, methinks.
Thread Tools
Display Modes
