Old 02-23-2010, 01:44 PM   #1
aric68
valve adjustment. help?
my buddy decided he wanted to adjust the valves in my 72 402. we tightened them down until we could not spin the push rod and then tightened them a 1/2 turn more. we followed a pattern we saw on line that allowed us to adjust half of them then rotate 1 turn and adjust the rest of them. well it sounds ok idling but put it into gear and it almost dies no power. whats wrong?
aric68 is offline   Reply With Quote
Old 02-23-2010, 01:48 PM   #2
67vetteal
Re: valve adjustment. help?
Your Valves are too tight. Back each nut uo until you hear a slight clicking sound. Then tighten just a half turn. That's 180*. Do this immediately or you may wipe out your Camshaft. Al W.
67vetteal is offline   Reply With Quote
Old 02-23-2010, 02:33 PM   #3
Myself
I agree, way too tight. You only tighten until initial drag is felt while spinning the pushrod with your fingers. If you tightened until you could not spin them, you probably went a couple turns too much.
Myself is offline   Reply With Quote
Old 02-23-2010, 03:55 PM   #4
Ticker
Don't adjust valves with the engine running.
Unless you have a radical cam, the companion cylinder method is quick and easy. Key point is as above...the very first time you feel any drag at all is zero lash.
http://www.carcraft.com/howto/ccrp_0...aft/index.html
Ticker is offline   Reply With Quote
Old 02-23-2010, 04:39 PM   #5
Phlebmaster
Phlebmaster's Avatar
That is a good article. I plan on using this method next time I adjust my valves. Last time I did mine was a mess! I had oil all over the place and the smoke was unreal.
Ticker, I just noticed all of the helpful links in your signature.
Thanks, Aaron
Life is about making dreams come true, stop dreaming and make life happen.
64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine.
Assumptions always lead to a dead end!
Phlebmaster is offline   Reply With Quote
Old 02-23-2010, 05:12 PM   #6
aric68
well the mechanic said the cam is gone, but it was running with an intake back fire with and acceleration before, and now it keeps trying to die when put in gear.
Old 02-23-2010, 05:15 PM   #7
Ticker
If you tighted down the cam too much...then you'd have wiped the lobes
The backfire was likely timing and/or fuel related.
Old 02-23-2010, 05:25 PM   #8
aric68
we timed it to -9 and dialed in the carb before we ever took off the valve covers.
Old 02-23-2010, 05:45 PM   #9
Wrenchbender Ret
What do you mean by "-9". You may have it timed too slow & your valves are OK. If it was popping back through the carb on accel. your mech. is probably right. You may have a bad cam. Run or turn the engine with the covers off & watch for a valve that barely opens.
Wrenchbender Ret is offline   Reply With Quote
Old 02-23-2010, 05:52 PM   #10
aric68
so the mechanic wants to charge me 1000 to replace the cam. how hard is it?
Old 02-23-2010, 05:53 PM   #11
aric68
i guess i mean 9 off top dead center
Old 02-23-2010, 05:55 PM   #12
Phlebmaster
It is not that hard. I did mine with no previous experience. Buy a kit if you can and follow the install and break in instructions for your new cam.
Here is a video I made of the swap>
This one might give more detail of the front of the block and cam gears
Put the engine at TDC for # 1,
Pull the distributor (after you mark it)
Then the intake
then the grill, radiator, water pump and the stuff attached, then the crank pulley/harmonic balancer, then the timing cover.
Then pull the timing gear/ chain.
Pull the fuel pump (there is a fuel pump lever actuator rod in the block)
Loosen the rocker adjuster nuts, pull the push rods, then the lifters (keeping them in order).
The cam should just slide right out. (be careful not to bung up the cam bearings)
Do the reverse to put it all back together.
Thanks, Aaron
Old 02-23-2010, 06:45 PM   #13
Ticker
"off TDC" can go either before (BTDC) or after (ATDC) - 9 BTDC is reasonable, the other way - you'd get the issues you're noting or worse.
You can ABSOLUTELY do this swap on your own with a little time and basic hand tools - 4 hours or so.
I have to note...that depending on how far the cam is gone, having the metal particulate in the engine is not good I've seen a fair number of bearing failures follow cam failures If you're not tearing it down, then there's nothing you can do about it other than do a couple of quick oil changes (right after cam break in, and then again at 1000 miles) and hope for the best.
Old 02-23-2010, 06:58 PM   #14
Phlebmaster
I almost forgot to mention........ You want to make sure you replace the lifters with the cam. It is not wise to reuse lifters unless you have them re-surfaced.
New ones are not that expensive.
Thanks, Aaron
Old 02-23-2010, 10:59 PM   #15
Myself
If it ran any longer than a few minutes with the intake backfire, I would bet there are chunks of cam metal imbedded in your crank bearings. I would just go ahead and pull the engine and check out the bearings too. The last time I had a cam failure it totally wiped out the crank.
Old 02-23-2010, 11:25 PM   #16
spinem
haha, ford guys...
your supposed to tighten until the rods stop spinning, then loosen. not tighten.
spinem is offline   Reply With Quote
Old 02-23-2010, 11:31 PM   #17
James Mc
I just had a cam failure in a 350. We pulled it out and the bottom of the oil pan was full of metallic oil, So I agree, You can do some quick oil changes and hope for the Best or even better, Yank it out and rebuild it. We replaced ours with a 383 Stroker. Going to redo 350 for an S10 we have.
James Mc is offline   Reply With Quote
Old 02-23-2010, 11:34 PM   #18
James Mc
Spinem
I've got an old Hanes manual that says to tighten to 0 tolerence then tighten 1/2 turn more. So if you tighten them until You just start to feel friction and tighten them 1/2 more turn they are good. Used this method many times.
Old 02-23-2010, 11:37 PM   #19
Sillyoldman
#16876
Sillyoldman's Avatar
My most recent cam install. Put in an Isky race cam in my 327. Yes replace your lifter rods timing chain or gears. Make certain that if you decide on a loppier cam that your heads will work with it. This was at initial start up. Not running well in video. Almost forgot, make sure to use cam lube and prime your oil pump before you stab the rotor.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 02-23-2010, 11:40 PM   #20
bikertim
Older big blocks are known for eating cams anyway -- 1 tip I got from a guy who knows these engines REAL well says ALWAYS use AC Delco lifters --- no matter what cam installed. Thats what i have in my 454 with ISKY cam now and works fine. Just my 2 cents --
Ditto on the metal in the crank bearings -- when my cam went flat almost 10 years ago (prior to the AC Delco lifters) I ended up spinning a main bearing after replacement. Cheaper to do now than replace a crank etc later. You could always just take a chance -- you may be ok -- but be aware it will be more expensive later! No matter what -- flush it REAL good!
bikertim is offline   Reply With Quote
Thread Tools
Display Modes
