Advance question
I've been trying to get my old 307 tuned and optimized as much as I can lately and I ran into something that is a little confusing.
I've got an old Mallory dual point distributor that I converted to electronic, so that's all good, but the advance has me a little puzzled. Mallory says the vacuum advance should start to come in at about 7". At idle (about 850 rpm) I've got 15-16". If I disconnect the vacuum line to the advance canister, the timing mark doesn't move. Do I have a bad vacuum advance unit or do I need a different one for lower vacuum? Also, at 850 rpm it appears that the mechanical advance is already coming in. Do I want to get a curve kit and put in some stiffer springs to move it up a bit? Tim
1970 C10 LWB with SB 307 & TH350 |
Between Trucks...
Re: Advance question
Are you hooked up to ported or manifold vacuum? The springs in the advance kits aren't that strong really. Might be better to grab some springs out of a distributor at a junk yard. Factory springs are usually stiffer then even the stiff springs in those kits.
Beat it to fit, Paint it to match... ![]() |
Oh yes. I forgot to mention. I'm running full manifold vacuum. Carter AFB, plugged into the port on the drivers side.
Between Trucks...
Might want to test the vacuum advance. This is on an HEI, but should be similar on yours.
Thread Tools | |
Display Modes | |
