Old 02-26-2010, 01:15 PM   #1
southbounddee
southbounddee's Avatar
How to fix an '03 cluster????
I have an '03 silverado and the temp gauge is stuck all the way around,and sometimes my speed is over by 5 or 10 mph, i know these clusters are junk, was wanting to know if anyone has had any luck fixing them?
southbounddee is offline   Reply With Quote
Old 02-26-2010, 04:32 PM   #2
bwood
bwood's Avatar
Re: How to fix an '03 cluster????
I have heard it is possible to fix them. I personally have never done it, all the trucks that I have had to deal with fell under the extended warr period that GM put on them after they had so much trouble. Each needle on the cluster has a small electric motor that drives it called a stepper motor. From what I have read, the can be found new on eBay. You might also look at www.dormanproducts.com as they have now started offering replacment clusters.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-26-2010, 04:37 PM   #3
JohnC
JohnC's Avatar
First off check with a local dealership and see if it is covered under the warranty. I just had mine repaired for the second time. Found a local guy that did it pretty reasonably. He said he does about 10-12 a month. There is also a place that I found on the web that I was going to send mine to, before I found someone local. If you want pm me and I can give you his info.
JohnC is offline   Reply With Quote
Thread Tools
Display Modes
