Old 02-26-2010, 10:58 PM   #1
TripleZ
A Arm Question + Rear Axle Question
I was hesitant to post this because I know it has been discussed before. I do do a search and could not find it. I have a 77 1/2 ton 5 lug, will the A Arms in the 77 fit into my 67 1/2 ton 6 lug. Will they bolt in without modification. I have the Energy Suspension Kit for the 77, plus the rims I want to use are 5 lug.
I know the rear axles in the 67 are different from the 77, if I decide to replace the axles to convert to 5 lug does any one have opinions on where to buy new axles, I heard the Dutchman makes a good axles at a decent price.
Sorry if this is a re-post.
ZZZ
TripleZ is offline   Reply With Quote
Old 02-26-2010, 11:05 PM   #2
SCOTI
SCOTI's Avatar
Re: A Arm Question + Rear Axle Question
77 a-arms will swap to the 67 no problem.
Conversion axles are available from ECE, Moser, CPP, & prob others as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-01-2010, 01:42 PM   #3
DKN
Active Member
The 77 control arms can work. You will need the ball joints for the 1967.You will need to use the arm shaft and bushings assemblies from the 77.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 03-01-2010, 05:59 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Danny Nix
CPP
You will only need the ball joints for the 67 if you reuse the 67 spindle and 6 lug hubs/drums. If you use the 77 spindle and 5 lug disc brakes, you will need the 77 bal joints.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-01-2010, 07:12 PM   #5
DKN
Active Member
Yea youre right. I was thinking of re-using the 67 spindles, and not thinking about which brake he has. Probably because we make 5 lug kits for the OE spindle.
Thanks for clearing up my misguidence.
Danny Nix
CPP
Thread Tools
Display Modes
