Old 03-01-2010, 12:17 AM   #1
Blazer Eagle
Ca smog
do older cars have to meet the same requirements as newer cars in term of smog? i was just thinking with the little things my 76 has is it going to be extremely hard to smog? or are the standards lowered?
Blazer Eagle is offline   Reply With Quote
Old 03-01-2010, 12:31 AM   #2
longbedrick
longbedrick's Avatar
Re: Ca smog
there are a few counties in CA that do not require smog. I used to have a '76. passed smog like a champ. it had true dual exhaust with no cats. smog tech told me that as long as all the factory smog components were intact, I could pass visual. my truck passed the sniffer test too.
longbedrick is offline   Reply With Quote
Old 03-01-2010, 12:40 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
Re: Ca smog
my 79 passed fine, still has the original cat on it. Its mostly visual since these earlier trucks dont have O2sensors and no computer to read off of. Just make sure your carb and timing are in spec of what its saposed to be and you should be fine, check all your vacuum hoses for cracks also.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-01-2010, 01:02 AM   #4
FLEET72
FLEET72's Avatar
Re: Ca smog
From the horses mouth: http://dmv.ca.gov/vr/smogfaq.htm
If you recently acquired the truck and have yet to transfer ownership you will have to smog it. If you have had it registered in your name already then El Dorado Co. does not currently require a bi-annual inspection. At least that's the way I read it.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-01-2010, 01:17 AM   #5
Blazer Eagle
Re: Ca smog
yeah i just bought it, the guy i bought it from told me it would pass smog and did run, i assumed it didnt and bought it for parts, luckily with new sparkplugs it fired up, its running a little rich but other than its not smoking or anything so i have high hopes, it has cats so that should help, the only bug i need to fix is the PO swapped carbs and didnt reconnect the coal cannister, the smog pump and everything else is still intact
what happens if you fail a test?
Old 03-01-2010, 03:24 PM   #6
spinem
haha, ford guys...
Re: Ca smog
standards will be the same as when the truck was sold the first time (off the lot) it must still have all the smog that came with the truck. (2 cats is illegal for example, even tho ur makn it more efficent, its illegal) ca sucks.
spinem is offline   Reply With Quote
Old 03-02-2010, 12:14 AM   #7
Blazer Eagle
Re: Ca smog
maybe it has one or none i dont really know, my dad was looking at something underneath and so i asked him, so who knows
how many are there supposed to be?
Old 03-02-2010, 12:17 AM   #8
spinem
haha, ford guys...
Re: Ca smog
should be 1. smog that year was header tube pick up /w/ air pump... if i remember right
Old 03-02-2010, 12:17 AM   #9
54Caddy
GM Addicted
54Caddy's Avatar
Re: Ca smog
should only be 1 i believe. Also if you can get ahold of a owners manual itll have the vacuum diagram in there for the hoses, i have one for my 79 worked perfect. Or if the radiator support still has the veci label then it should have the diagram right on it.
..Mac’s Garage..
IG:MacsGarage
Old 03-02-2010, 12:21 AM   #10
Blazer Eagle
Re: Ca smog
i think everything is set up correctly, there is a line going from the cannister to the carb, however instead of connecting to the carb it is just laying on the intake, its an edelbrock 1903 if anyone knows where it should hook up
Thread Tools
Display Modes
