Old 03-04-2010, 08:10 PM   #1
jyaughn
jyaughn's Avatar
stock rear end
what rear end came in a stock 1/2 ton step side with a inline 6 three in the tree tranny? the truck is a 62 btw
jyaughn is offline   Reply With Quote
Old 03-05-2010, 01:58 AM   #2
Captainfab
60-66 Nut
Re: stock rear end
The '60-'62's came with what some call the GM55T which has a drop out 3rd member as well as a removeable rear cover. They usually have 3.90 gears in them.
Old 03-05-2010, 10:11 AM   #3
jyaughn
jyaughn's Avatar
Re: stock rear end
is that a good rear end to use when i do my v8 swap?
Old 03-07-2010, 01:26 AM   #4
Captainfab
60-66 Nut
Re: stock rear end
If it is in good condition it will hold up just fine. With that gear ratio I would consider an OD trans such as the 700R4. But that depends on your intended use of the truck and of course your budget.
Old 03-07-2010, 05:40 PM   #5
jyaughn
jyaughn's Avatar
Re: stock rear end
im going with a turbo 350 tranns. its just going to be a weekend play to to cruise around town in
Old 03-07-2010, 05:41 PM   #6
jyaughn
jyaughn's Avatar
Re: stock rear end
where could i go to buy a posi unit for the rear end
Old 03-08-2010, 01:13 AM   #7
Captainfab
60-66 Nut
Re: stock rear end
I don't think there is anyone that makes a posi for those rear ends. You might try searching ebay for a used original one, but they would likely be rare.
Thread Tools
Display Modes
