Old 03-07-2010, 07:41 AM   #1
bosephus
bosephus's Avatar
opinions on my differential dilemma
Hi all! I have a 61 chevy with what I believe is called the HT55 rear end(drop out third member 3.90/1) that is leaking oil at the pinion.This rear end has a limited slip carrier and the ring and pinion looks fine to me(which means I don't see any huge pits or missing teeth). I also have at my disposal a 12 bolt 3.73/1 truck rear from a 65(I think) that doesn't have the limited slip and needs to be rebuilt.I dont know which way to go on this one.Are there parts still available for the HT55 and where would I find them?Is the HT55 worth rebuilding or should I bite the bullet and buy the parts and limited slip for the 12 bolt?Should I just keep adding oil and call the resulting mess rust preventionAlso,I dont mind the steep gears because i'm running a TKO overdrive transmission.Any input is appreciated(I think) Thanks
bosephus is offline   Reply With Quote
Old 03-07-2010, 11:57 AM   #2
mbgmike
Re: opinions on my differential dilemma
I would probably switch it out unless wanting to keep it original. Here is a company that provides us parts and maybe of some help.
http://www.sandstruck.com/landpart/drivetrain.htm
They are Manufacturers so not sure how much help they will give you.
You may want to contact Ratech
http://www.ratechmfg.com/toc.htm
mbgmike is offline   Reply With Quote
Old 03-07-2010, 01:08 PM   #3
62gmc910
62gmc910's Avatar
the HT 55 was sold to toyota for use in the older landcruiser so parts should still be available . if you choose the later 12 bolt , parts are fairly common right up to 80 giveing a lot more ratio selection, but you will need to relocate the mounting pads and maybe adjust the panhard
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 03-07-2010, 03:47 PM   #4
bosephus
bosephus's Avatar
Thanks Mike,I figured that changing it out would be best.I dont really care about keeping it original,It just has to be able take a little abuse!
Old 03-07-2010, 03:58 PM   #5
bosephus
bosephus's Avatar
Thanks for the reply 62GMC,I was hoping the 65 truck 12 bolt would just bolt in but I should have known it wouldn't be that easy
Old 03-07-2010, 05:07 PM   #6
K-TEN
Personally, I'd fix it, You say that you have everything that you need. Mounting, correct ratio, posi. Why change it? Take it to a shop that knows what they are doing and get the seal replaced. Once you pull out the old seal, you'll know the p/n for the new seal. Can you honestly tell me that you'll spend less money on a swap than a seal repair? No way. Plus you have to find the new posi. Economically speaking, this swap is a loser.
The shop manual shows how to replace the seal. Some special tools are necessary, but your mechanic has done a bunch of these already.
And if you think you'll tear up your current rear end with all that horsepower, when it blows up, THEN replace it with that 12 bolt. My bet is it's going to be a Loooooong time before that happens. JMHO
K-TEN is offline   Reply With Quote
Old 03-07-2010, 05:14 PM   #7
777ralph
Why change it? you've got a rear that's already under the truck, has limited slip, and has a ratio you're OK with. Fix the seal. Done.
The other rear may need modifying to fit, has a similar gearset, no posi, and needs rebuilding to boot.
I don't care about staying original, but that seal can't be that hard to find. Seems like way less work and money.
Ralph
777ralph is offline   Reply With Quote
Old 03-07-2010, 05:42 PM   #8
bosephus
bosephus's Avatar
I agree with you about it being cheaper and there would be nothing lost by trying to get the old seal out to ID it.I thought that when I broke the pinion nut loose I would need to set the lash in the gears again(never done this)I guess I need to get a shop manual and give it a try! Thanks
Old 03-07-2010, 05:44 PM   #9
bosephus
bosephus's Avatar
Ralph
All good points,Thanks!
Old 03-07-2010, 05:45 PM   #10
jyaughn
jyaughn's Avatar
off topic but did you sand blast your frame to get it the clean?
jyaughn is offline   Reply With Quote
Old 03-07-2010, 06:05 PM   #11
bosephus
bosephus's Avatar
I blasted it with a HorribleFreight sandblaster,two stage compressor and about 600 lbs. of black beauty.I still get sandy feet when I wear those shoes from that day
Old 03-07-2010, 06:48 PM   #12
jyaughn
jyaughn's Avatar
lol so i need to blast mine
Old 03-07-2010, 07:18 PM   #13
62gmc910
62gmc910's Avatar
I missed the part about your axle being OK other than the pinion leak, build your self a yoke wrench basicly a piece of plate that you can bolt to the u joint clamp holes and put a 3 foot handle on it , it needs a hole in the center for the socket to undo the pinion nut , if you pull the yoke without disturbing the bearings, you should be able to replace the seal with out worrying about changing the preload much . make sure you lube the seal surface and loctite the nut . the repair should only cost you $20.00 and your time , if you somehow scrwe it up which is pretty hard you were thinking of a new axle anyway
Thread Tools
Display Modes
