will 15's fit with front disc brakes??
i just switched my c20 to 6 lug disc brakes, i don't have rims for it yet so do you guys know if i can run 15'' steel rims or do i need to go to 16's to clear the calipers? i want to run narrow rims, like 5", with bias whites.
'66 c10ish straight 292 power! |
Senior Enthusiast
Re: will 15's fit with front disc brakes??
I've run 15x6 steel wheels and 15x5 mags on factory 1975 five lug disc brakes. Unfortunately I don't know the diameter of the 6 lug rotors. If they are the same size as the 5 lug rotors you shouldn't have a problem. You'll probably need to use "disc brake" wheels however. The back side of original 50's-60's factory drum brake wheels have a tapered funnel shape that generally will not clear disc brake calipers. On the later disc brake wheels the rear of the wheel is more of a straight cylinder shape providing the needed clearance.
I have '66 with 6 lug and CCP disc brake conversion, running on 15 steel with no problems.
sweet, thanks guys for the info!
![]() Join Date: Nov 2007
I have the same setup as C10Slim. I run 15X8 crager chrome steel 6 lug wheels but I had to use 1/4" wafer spacers to clear the calipers.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Resistance is Futile
15'' truck rallys clear my dropped spindles and brakes by about 1/16th of an inch. I was just under there and noticed how close it was; works fine.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Rods
![]() Join Date: Nov 2002
Stock 66 wheels will not clear. On six lug disk with stock parts. However i do have 15 steelies from a 3/4 van and they clear
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
HOW long until spring??
![]() Join Date: Mar 2009
I am running 15" aluminum rims with CPP GM rotors and calipers and no clearance problems.
Some older steel rims do not have a relief edge in the back side of the rim. It was put there in later years to allow clearance for the calipers. check the back side on your rim , to see if there is a "step down" for clearance in the backspace area.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Thread Tools | |
Display Modes | |
