Old 03-14-2010, 02:57 PM   #1
tk-mpl
tk-mpl's Avatar
2007 LS 5.3L no start......
Well everything is in and wired. I have no spark and no noid.... I wired the starter relay enable right off of the ign. switch so it does turn over. We disabled the passlock (vats) with EFI Live. I have crank signal, you can watch the rpm on efi scan tool......
I have power and ground at coil with key on and while cranking. Also have power at injector....
could use some help...
Trevor
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 03-14-2010, 03:38 PM   #2
clinebarger
Re: 2007 LS 5.3L no start......
Did your engine come out of a silverado classic or a silverado (old or new body style)?
The reason I ask is because the new silverados have a gen IV 5.3.
clinebarger is offline   Reply With Quote
Old 03-14-2010, 03:43 PM   #3
tk-mpl
tk-mpl's Avatar
It is out of a new body style tahoe. It is a 5.3L LMG..
Old 03-14-2010, 04:14 PM   #4
clinebarger
Are the cam & crank sensors plugged in? Have you checked all the grounds coming out of the harness? Im guessing there are no codes?
Ive always sent my computers out for VATS, how are you sure you flashed the PCM correctly?
When i have VATS problems they start for a couple seconds and die, but not sure on the gen IV controller.
Who modified the harness? Are you using the stock harness and PCM?
Was the doner truck in a wreak, damaged harness? Damaged sensors?
Old 03-14-2010, 04:18 PM   #5
tk-mpl
tk-mpl's Avatar
I am kind of wondering because the PCM isn't seeing a crank request that it isn't enerrgizing the coils or injectors...
Old 03-14-2010, 04:20 PM   #6
tk-mpl
tk-mpl's Avatar
I can watch the rpm with efi while cranking and cam phasing counts aswell.
Old 03-14-2010, 04:38 PM   #7
blazerboy72
Is the gas pedal plugged in? Mine was doing the same thing and the plug on the pedal wasn't all the way in.
blazerboy72 is offline   Reply With Quote
Old 03-14-2010, 04:41 PM   #8
clinebarger
Without a body contol module it will not see a crank request.When the ignition switch is placed in the Start position, a discrete 12-volt signal is supplied to the body control module (BCM) notifying it that the ignition is in the Start position. The BCM then sends a message to the engine control module (ECM) notifying it that CRANK has been requested. The ECM verifies that the transmission is in Park or Neutral. If it is, the ECM then supplies 12 volts to the control circuit of the crank relay.
This should not keep the engine from starting.
You didnt answer the questions i asked? I can not help you without more information.
Old 03-14-2010, 04:51 PM   #9
tk-mpl
tk-mpl's Avatar
I checked all powers and grounds to pcm and all other grounds that were on the harness.
Not sure on the reflash as a friend came over and did it..
No start at all because have no spark and no injector pulse..
I am using a stock modified harness by me..
asfar as I can tell all needed sensors for starting are working.. Did not see any defects while rewiring.
Old 03-14-2010, 04:55 PM   #10
tk-mpl
tk-mpl's Avatar
I know how the starter circuit worked, that is why I wired the starter relay off of the ign. switch.. I thought with all powers and grounds and then sensor inputs while cranking it would start.
Guess not....
Old 03-14-2010, 05:01 PM   #11
tk-mpl
tk-mpl's Avatar
pedal is plugged in..
Old 03-14-2010, 05:09 PM   #12
ShredSled
ShredSled's Avatar
shot in the dark, but does it have anything to do with the GenIV higher resolution reluctor wheel?
get it!
ShredSled is offline   Reply With Quote
Old 03-14-2010, 05:11 PM   #13
clinebarger
Guess not....
I agree it should.
No codes right?
Has your buddy ever flashed a 07 before?
Old 03-14-2010, 05:16 PM   #14
clinebarger
The 58x crank sensor should not be a problem aslong as he is using the correct PCM.
Old 03-14-2010, 05:20 PM   #15
tk-mpl
tk-mpl's Avatar
The only codes that have set are EVAP crap I haven't deleted yet and p0615 and p0690.
Ted's experience with EFI is mostly with diesel stuff, but he knew exactly how to turn vats off..
Old 03-14-2010, 05:37 PM   #16
killer71
killer71's Avatar
put gas in it...just kiddin, pm short step!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-14-2010, 05:43 PM   #17
clinebarger
DTC P0615
The engine control module (ECM) supplies 12 volts to the control circuit of the STRTR relay when start enable has been requested. The ECM monitors this circuit for conditions that are incorrect for the commanded state. If the ECM detects an improper circuit condition, STRTR relay DTC P0615 will set.
The ECM detects an improper voltage level on the control circuit that controls the STRTR relay.
Ignition system DTCs set with the ignition switch in the START position if the STRTR relay or the starter is inoperative. When the ECM enables starter operation, the ECM also initiates the diagnostic test routines for other DTCs. If a condition exists which prevents the engine from cranking, the ECM will not receive signal input from the crankshaft position (CKP) and camshaft position (CMP) sensors, and the DTCs will set.
DTC P0690
The ECM detects more than 16 volts on the ignition 1 voltage circuit to the ECM when the relay is commanded ON.
The ECM detects more than 2 volts on the ignition 1 voltage circuit to the ECM when the relay is commanded OFF.
Old 03-14-2010, 05:52 PM   #18
tk-mpl
tk-mpl's Avatar
do you think if I turn that code off (p0615) with efi that it would help??
Old 03-14-2010, 06:08 PM   #19
clinebarger
It whouldnt hurt.
Old 03-14-2010, 06:25 PM   #20
Ackattack
Ackattack's Avatar
do you have power to the ECM while you're cranking?
I hooked up a TPI engine and fought with it for a day or two until I realized that I didn't have power to the ECM while cranking, but did have power in the "on" position. Good luck, it can get frustrating in a hurry when it "should" work.
Might want to check out the "hybrid" section at LS1tech.com and see if someone there can give you some insight too.
Ackattack is offline   Reply With Quote
Old 03-14-2010, 06:39 PM   #21
tk-mpl
tk-mpl's Avatar
I got posts on hear, efi live forum and ls1tech..
power is there while cranking..
Old 03-14-2010, 07:00 PM   #22
tk-mpl
tk-mpl's Avatar
Not sure how much you guys know about this system, but the pcm isn't even enabling the powertrain relay which powers the coils, injectors, o2 sensors, and MAF sensor. I wired it differently with a current performance fuse block, but that circuit should have 12V with key on..
sorry it grounds the relay and it is there..
Old 03-15-2010, 02:08 AM   #23
Ackattack
Ackattack's Avatar
I used a current performance fuse block too.
Do you have any way of testing the ECM.
I fried one ECM. I took it out of my 68 and put it in my 05 and had the same issue in the 05 so I knew it wasn't the wiring or anything else, only the ECM. If it works in an 07, then you know it's something with your wiring.
Old 03-15-2010, 09:20 AM   #24
Sub71
Double check your grounds and connections.
I pulled the power steering pump off one time and forgot to hook a ground back up there and it wouldn't start. It won't start without the alternator plugged in as well.
I built my own harness as well, did you ground all the black wires?
Sub71 is offline   Reply With Quote
Old 03-15-2010, 02:05 PM   #25
tk-mpl
tk-mpl's Avatar
I got to leave today for work, but when I am home next week I should pull my 08 pcm out and see if it will work.... I really thing it is a crank request issue though..
Trevor
Thread Tools
Display Modes
