Old 03-14-2010, 10:25 PM   #1
Farmstore34
Farmstore34's Avatar
Angry Clutch
Well guess what,
I installed a brand new clutch in my 72 K20, did everything by the book, started it up and the dumb clutch is making a terrible rattling/scraping sound right from the pressure plate. It does it whether its engaged or disengaged, and gets worse as the RPMs go up. Now I get to pull it all back apart, and I really need my truck. Frustrating!!
Farmstore34 is offline   Reply With Quote
Old 03-14-2010, 10:34 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Clutch
It sounds like you might have the clutch plate in backwards... One side should be stamped "Flywheel" or "Flywheel Side".
LockDoc
Leon
Old 03-14-2010, 10:37 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
Re: Clutch
Sorry to hear that you have problems with the clutch you installed. Hopefully it is not anything major.
We installed a clutch in my '71 this weekend and luckily everything went ok. It was a real pain getting the engine in and I sure was not looking forward to pulling it back out or dropping the heavy 4 speed.
Good luck.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-15-2010, 01:28 AM   #4
Farmstore34
Re: Clutch
I'm sure the clutch plate is on the right way, but I guess I will find out. And, of course I have to deal with the transfer case as well as the heavy SM465.
Old 03-15-2010, 02:06 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Clutch
did you replace the throwout and pilot bearings? both of those would change sound when the clutch was engaged/disengaged though....not sure what it could be. Let us know when you find out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-15-2010, 02:51 PM   #6
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
Re: Clutch
did you put on a new flywheel, or get the old one ground? thats what it sounds like to me.
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
Old 03-15-2010, 03:06 PM   #7
DPowers
DPowers's Avatar
Re: Clutch
I had a sound something like that on my automatic- it was the dust cover rubbing against the flywheel.
DPowers is offline   Reply With Quote
Old 03-15-2010, 08:04 PM   #8
69 longhorn
Re: Clutch
i agree, ....pull the dust cover & see if the problem goes away. crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-16-2010, 01:20 AM   #9
Farmstore34
Re: Clutch
I installed all new parts- pilot bearing, T/O bearing, pressure plate etc. I did have my original flywheel resurfaced, but I'm not sure how that could cause the noise. I also thought of the dust cover rubbing, but I pulled it off and ran it- no change. The noise is definitely coming from the pressure plate. Hopefully I'll get up enough energy to take it all apart this week and find the problem.
Old 03-16-2010, 03:06 AM   #10
Trip59
Who needs sleep...
Trip59's Avatar
Re: Clutch
I just swapped in a 4spd from a TH350, brand new flywheel, brand new clutch kit and bearing, aluminum housing from a 60's chevy in great shape, the 4 speed was professionally rebuilt. Started it up and heard a noise like beans in a coffee grinder (well, how they sound at first). Same symptoms, but then it would go away and come back occasionally.
Before panicking and yanking it back apart I thought about it...
I shimmed the starter and the noise went away.
Trip
Trip59 is offline   Reply With Quote
Old 03-16-2010, 06:04 AM   #11
GMC AMI
GMC AMI's Avatar
Wink Re: Clutch
I found it easier to pull the motor on my 4x4s to do the new clutch. I also found the best place to buy new HD clutches In FT. Wayne. I have bought two of them brand new, not rebuilt ones, for around 100 bucks with everything included even the alignment tool. The local NAPA wanted close to 300. I have been real happy and if someone wants to know the place send me a PM and I would be glad to help.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 03-25-2010, 12:56 AM   #12
Farmstore34
Talking Re: Clutch
Guess what! I DID NOT put the clutch disc in backwards! I am sorta relieved, but now I have to take it back to the parts store and see about a replacement.
Colby.
Old 03-25-2010, 01:19 AM   #13
NORMSCOLORADO
NORMSCOLORADO's Avatar
Re: Clutch
what happened loose rivets?
04 Chevy Colorado Z71 4X4
76 Chevy C-10 Custom Deluxe (sold)
67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel
NORMSCOLORADO is offline   Reply With Quote
Old 03-29-2010, 03:51 AM   #14
Farmstore34
Smile Re: Clutch
Well, I finally got the clutch installed, and it works great. My parts guy exchanged the first one out, we still have not figured out what was wrong with it. This apparently was the first bad clutch he ever had come back. I am relieved to have this project done!
Old 03-29-2010, 09:00 AM   #15
DPowers
DPowers's Avatar
Re: Clutch
Congrats- glad it worked out.
Thread Tools
Display Modes
