Who needs sleep...
![]() Join Date: Aug 2009
Steering column help... to tilt or not to tilt?
Ok, so I get the truck, it has a van tilt crammed into the dash. At the time it was an automatic with column shift.
I buy a floor shift manual trans non-tilting column in really good shape from a board member. Take it apart, clean it up, and in the process drop the rear aluminum cover/cone piece... So I hammer it back into shape (with a wood dowel, relax) and get the column back together today, put it in and... ![]() pulled so far it's jammed into the dash and it's STILL short enough that the shaft comes out trying to get it into the joint. The gearbox is manual, from the rag joint to the point in the knuckle where the column shaft goes is about 13" Is it the wrong lower shaft? Did someone crush it? So I'm looking at this all, and while I like the simplicity of the non-tilt column, the tilt is a nice feature... I'm thinking about maybe rebuilding it and using it (else I'll be selling it here soon) but the turn signal component is missing a few things. It looks the same as the one from the other column, would they swap over? What would you do? Here's the tilt in the dash, so it seems the lower column is too short to begin with, but that tilt sticks waaay out into the cab. ![]() Trip |
Re: Steering column help... to tilt or not to tilt?
It looks like the shaft extension has been collapsed. If it is in good shape you can pull it back into the original position. I believe that it is 17" long originally.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Who needs sleep...
Ok, now for the big question... do the holes the plastic pins used to be in go all the way through? In otherwords, I take this out, yank on it... can I tell where it was factory by holes going all the way through?
Trip |
No, the holes do not go all the way through.
Dustydog 1940 Ford 2D SDN 1970 GMC SB 2004 C5 Vette |
Who needs sleep...
If it comes apart you pulled it too far! Sorry, that was just too easy
![]() I put a tilt in mine and shortend it about a month ago, it seemed like there was a lot of room to move it in or out. I needed more room between my big belly and the wheel so I pushed it in as far as I could. Dusty
![]() Join Date: Aug 2008
The shaft that I used- the holes did go all the way through. I put a tilt column from a '64 Impala in mine. I redrilled and repinned it.
#8 | |
Who needs sleep...
![]() I actually want to keep it a bit short, but not so short the column is jammed in the dash. I'll just have to make sure to record it so I can post the smack on YouTube tomorrow... Trip |
Who needs sleep...
OK, so I DID IT!!!
(now I wish I took pics, will charge the camera before next project) Thanks to everyone for the advice. I split the rag joint (and looked like a fool trying to put the wrong nut on the wrong bolt...) and lo and behold, the shaft was compressed so far the end was at the joint. Stuck a piece of conduit in there and whacked the hell out of it with a 5lb fist maul. Knocked it about 4" back, set everything back in the truck and then put some vice grips on it to tap it back down about 3/4-1 1/4" so the column was in the cab as far as I wanted. Bolted back up, took it out for a spin, all is GOOD!!! The rear cone on the column is still tweaked, either need a new one or to spend an afternoon playing with it. Steering wheel is screaming for a resto, though I want to put a '67 on it. Next steering issue is to adjust the manual gearbox...next weekend. I'm going to clean up the tilt and list it in a few days, it's a van tilt, not bad shape, but needs a couple bits and pieces and some TLC. Again, thanks to all for the advice! Trip |
Congrats
Thread Tools | |
Display Modes | |
