Old 03-27-2010, 11:19 PM   #1
67ss&99ss
Andy
Talking I upgraded to power brakes today!
Well, I converted my truck to power brakes today. I must say that the difference is unbelievable. Before I had to stand on the brakes to get it to stop. Now, it's effortless. If you have a manual drum brake truck, this is a cheap, fast upgrade that will make driving your truck much more enjoyable. Start to finish it took me an hour. It took me more time to find the right tools than to do the swap. You can use your existing master cylinder and you don't have to unhook the lines it either. Just bend your lines to match up to the booster after you bolt it onto the truck. The wire that runs to the proportioning valve will need to be extended. I have not done this yet. I need to take it back off to clean it up and repaint it, but today I was only interested in seeing if it worked or not, since it came off of a parts truck.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 03-28-2010, 12:10 AM   #2
GMCMAX
Active Member
GMCMAX's Avatar
Re: I upgraded to power brakes today!
Didja bang your head on the first stop like I did? Thirty years of full weight on the pedal takes a while to unlearn! Best easy upgrade for these trucks.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 03-28-2010, 12:12 AM   #3
Schwinn68
Schwinn68's Avatar
so basically, all you did was bolt in the booster behind your existing master cylinder? Is it just one vacuum line that powers it all up? It can't be that easy can it? I've got a booster and master out of an 91 chevy that I could split up and bolt in right now if all this is true.
Ben
_____________________________________
1971 Chevy shortbed 350/4-speed sold
2005 Chevy Duramax EC/4x4
Local 597 Pipefitters
certified TIG MIG and stick welder
Schwinn68 is offline   Reply With Quote
Old 03-28-2010, 12:19 AM   #4
67ss&99ss
Andy
It's that easy. However, I do not know if the later model booster will work. Mine came off of a '71 truck.
Old 03-28-2010, 12:21 AM   #5
67ss&99ss
Andy
Luckily I didn't. After reading about the swap for a while on the forum I was prepared and applied the brakes with care.
Old 03-28-2010, 12:50 AM   #6
ERASER5
ERASER5's Avatar
I will work, not exactly correct, but it will work. The brakes will be touchy.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-28-2010, 12:57 AM   #7
dan42
dan42's Avatar
Rod length out of the back of the booster needs to be checked for correct length - also, the 3/4 ton and 1/2 ton boosters are different.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-28-2010, 10:50 AM   #8
Schwinn68
Schwinn68's Avatar
may not be the cheapest way but autozone has these brand new including the master cylinder for about 130-150 depending on which booster.
Which booster is recommended for our trucks? Autozone offers either Bendix or Delco
Ben
Old 03-28-2010, 11:01 AM   #9
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Trick is find the brackets or modifying the 73-87 booster/bracket...
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 03-28-2010, 02:19 PM   #10
srea76
srea76's Avatar
I just got a booster off a parts truck. My truck is a 72. Could I use my same prop valve and mc?
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 03-28-2010, 03:22 PM   #11
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I just did this a week or so ago to find out the PO had the distribution block in backwards I need to make up the correct lines from the MC but yes this is an easy project and takes about an hour..be sure to check your brake switch/lights I had to swap my rod to the peddle too
what does your bracket look like?? this is mine before paint
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-28-2010, 10:16 PM   #12
67ss&99ss
Andy
Yes, you use your existing proportioning valve and master cylinder. When I pulled the booster off of the parts truck, I also got the rod that goes to the brake pedal that Hottrucks mentioned. This will have to be changed out too, but it isn't a big deal.
Old 05-03-2010, 10:09 PM   #13
Roadmarks
Roadmarks's Avatar
Howdy, COACHMEASON mentioned modifying the '73-'87 booster bracket. Can someone go into more detail on what has to be done. I am unable to find a '71-'72 bracket and rods around here which is Raleigh NC.
BTW, The local Advance Auto Parts stores have a rebuilt Bendix set-up, (master/booster,) For about $105.00! Their part number 50-3709.
best wishes,
Les
Roadmarks is offline   Reply With Quote
Old 05-04-2010, 10:16 AM   #14
flashed
If you really want to UPGRADE your brakes let Frank (pickmup I think) ,build a new master cylinder/booster for a 3/4 ton for you .All new parts ,easy to install and stops better than my wifes 96 Explorer with 4 wheel discs. It was very reasonably priced ,and better brakes than I thought possible .
flashed is offline   Reply With Quote
Thread Tools
Display Modes
