Old 03-30-2010, 12:06 PM   #1
KFreddy
Active Member
KFreddy's Avatar
Consolidated Rant: DIY4L80e Computer Swap
DIY4l80e Computer Swap is a topic that comes up time to time, this is a fresh post in response to consolidate information, the disjointed wheel and tire threads drive me insane but that's another issue altogether...
I hope this helps someone out in some way...
My trucks been parked for close to 7 months after I lost 2nd gear on the TH400, at first I was looking to rebuild the Th400 for a few hundred bucks, then I wanted more of an upgrade to handle 600+ HP then I contemplated a new HD tranny swap/ rebuild. Every thought got more and more expensive, $700 for a Yank converter alone After months of "counting sheep" at night figuring out the tranny situation as I went to sleep I found myself completely over the idea of spending a dime or my time fixing the Th400 when what I really want is a 4 speed auto, a 4l80e. I know this is different for everyone but at the end of the day I'm a damn good electrician so that someone else can be a damn good mechanic...
My Logic
5-6 years ago a HD rebuilt 4l80e was relatively cheap, reason being there was close to zero aftermarket stand alone computer knowledge, setup or support for these trannys, nor was there a huge demand for HD upgrades because of the latter. The stand alone TCU's that did exist, TCI's 1st gen TCU and the Bauman TCU were $400 to $600 and they still had their issues and needed a laptop. There are a few home brew Diesel TCU's out there however you needed a degree in "Underwater Rocket Science" just to read the code/tables never mind programming the code and tables. After a lot of maturity, and US DOD contracts, the aftermarket has caught up to the 4l80e's needs and with it the pricing has gone up for TCU's however so has the technology, usability, tune-ability and support. Check the pricing for a quality built 4l80e now close to $3000 or more, people want to be using this set up as it works really, really well.
Tranny control units and Transmissions
Computers from 2500 and 3500 Vans from 1992 to 1996 with mechanical injection and no turbo came with a separate transmission control unit. These are the computers that you want. $25.00 to $150.00
Turbo Diesel Trucks use a ECU not a standalone TCU, so there is a need to clear the upper tables and then flash and reprogram the lower tables.
'91-'92 same ECU or '93 different ECU and harness need to be used with '91-'93 transmissions and though these will all work together a non specific year will take more programming knowledge to interface. '94-'96 ECUs can be used on '94 and newer transmissions.
Reverse engineering the software/ DIY
Not to wee in anyone's cornflakes, however the wonderful thought of a cheep junk yard computer for $39.99 just doesn't pan out. If it were that simple a lot of people would be doing it this way. This is what I figured that I needed to get it done with the approximate cost. (I don't have a brother's uncle's Friend who owns a junk yard that happens to be a retired GM transmission Engineer.)
Hardware, Sensors, Schematics and Knowledge:
Laptop Computer Have one already or $250-500 on ebay
USB/ALDL-1 $85
USB/ALDL-Y cable set $120
OBDI TDF Files $50
Piggyback- chp adapter PROM/ECM $40
PROM Free to $55
TPS $25-50
VSS from a 91+ Transfer case $70
digital ratio adapter controller $80 http://www.dakotadigital.com/index.c...rod/prd126.htm
Harness Junk yard cost to $150.00
OBD-I real time scanner $250-$500 or the one you
just sold at the last garage
sale for $15
Manual locking toque converter switch
and harness or build your own. $100-$300
Wiring Diagram Free
Programming Tables Free
A switched 12V source Free
A degree in Underwater Rocket Science Priceless...
All that being said. and I'm sure I'm missing some of what is needed. your already conservatively at $700 to $900. Then to figure your time and the learning curb, the soldering and the head ache of programming dozens and dozens of lines of code though the satisfaction of accomplishing this yourself would be amazing, just make sure you have the laptop, scanner and cables if it dies on the side of the road on a road trip or a run to the grocery store...
Alternatives
If you do not mind shifting the tranny your self you could get a new valve body so you do not need a computer.
Transgo vacuum modulator Stage 3 kit $250
redrilled valve body core $100-$250 or DIY
Art Carr offers a full manual control harness $200
Painless Wiring also makes some sort of Transmission Controller though it's like $600 and the description is weak, calling tech support left the tech scratching his head and more confused then I was.
Off the shelf stand alone transmission computers
Compushift $1200 with harness, TPS and carburetor linkage, no laptop needed
TCI $750 + $150 for harness, needs laptop
GM $1100 with harness, needs laptop
PCS $1400 with harness, needs laptop -
Notwithstanding Compushift, a very good product; PCS is the # 1 reason that any TCU has made it's way into the consumer market, via SEMA show attention. Featuring in field hot swap capability laptop, TCU and correct harness are all that is needed to get just about any any electronic transmission up and running.
This list includes:
Ford AODE, 4R70, E4OD, 5R55E, 5R110
GM 4R100, 4L60E,4L65E, 4L70E, 4L80E, 4L85E, 4T40E, 4T45E, 4T60E, 4T65E,4T80E, GM 5L40/50
Mazda R4A-EL
Mitsubishi F4A3/W4A3
Nissan RE4R03A/RE4R01A
Toyota A340, U140, U340
Mercedes/Chrysler 722.6
PCS is the Granddaddy of ECU's, got a Humvee 1 or a M2 Bradley IFV, not a problem, transmission shot in that Taliban Toyota truck that was just commandeered PCS has got that covered too...
Keep in mind that both the TCI and the GM unit are made by PCS just re-badged. The PCS gives you the most control with their software the GM unit a bit less control and the TCI unit even less.
At the end of the Day well at the end of 7 months of saving and researching and saving and thinking and a little more saving I went with the GM controller and a 2010 4l85e Supermatic transmission. I figure for me it's the most complete and cost effective way to go about this, I've got enough uncharted water in my life and at the end of the day I just want to enjoy driving my truck...
Hope this rant helps someone out...
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 03-30-2010, 12:39 PM   #2
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
Re: Consolidated Rant: DIY4L80e Computer Swap
Good writeup / rant.
I've got a Compushift that I'm close to wiring in for my 4L80E, but it's nice to see someone presenting all of the available options.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 03-30-2010, 02:08 PM   #3
crakarjax
crakarjax's Avatar
How much do '92-'96 van 4l80e's go for from a junkyard?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-30-2010, 02:30 PM   #4
jojo
printing is my trade
jojo's Avatar
Ain't nothin wrong with gathering all the info and assembling it in one place. Things do tend to get scattered, but thats the nature of the forums. I would never be good at completely writing up and detailing any install since I am simply not a detailed person.
Its not a swap I'd be interested in due to complexity, but I'm sure this article will help some folk.
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 03-31-2010, 05:23 AM   #5
KFreddy
Active Member
KFreddy's Avatar
Ive seen them between $45 and $120.
Old 03-31-2010, 05:27 AM   #6
KFreddy
Active Member
KFreddy's Avatar
What are you planning to use for the TPS switch on your carburetor or are you order Compushift's linkage? Seems to me that the TPS is the one sensor that really controls everything on the 4l60e and 4l80e.
Old 03-31-2010, 01:10 PM   #7
68 SWB
68 SWB's Avatar
I think he meant the transmission it's self, not the computer. So it seems like this is quite the costly undertaking! For the cost of some of the controllers it seems like you could just get a late model drivetrain and use the engine and transmission and avoid the controller all together?
68 SWB is offline   Reply With Quote
Old 03-31-2010, 01:44 PM   #8
nuke1
nuke1's Avatar
great write up, I have a TCU going into my truck with a 60e, thinking the 85e would be nice thou.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 04-01-2010, 01:25 PM   #9
Beelzeburb
Beelzeburb's Avatar
I've actually got a TBI engine, so it's a simple matter of plugging the right connector into the TPS on the throttle body, adding TOSS and the VSS. I've seen that linkage of theirs as I've perused the instructions a few times. Seems like a relatively pain free way to go.
Old 04-01-2010, 05:21 PM   #10
KFreddy
Active Member
KFreddy's Avatar
Your existing set up for the TPS will work perfect, you might need a TPS
Y-connector at most, nice and painless. I spent a good amount of time this morning looking over the software set up for the trans controller looks pretty straight forwards, heck I'll know for sure by the end of next week...
Thread Tools
Display Modes
