Timing Marks and Timing
After fighting the carb rebuild I finally got the truck to idle and run a bit better. I hooked up a timing light to set the timing but could not find any timing marks on the crank pulley. I brought No. 1 to TDC and checked the pulley again, but nothing. Am I missing something.
Ed |
![]() Join Date: Aug 2008
Re: Timing Marks and Timing
No groove line on the pulley?
Do you have a timing tab on the timing gear cover? |
The groove is actually on the Harmonic Balancer and the marks should be on a tab that is on the timing gear cover. If you have a lot of paint build up or grease on the Harmonic Balancer you might not be able to see the grove on the Balancer.
I'll look again tomorrow. I do have the timing tab on the timing cover. Anybody have pics of what it looks like.
283
C10 CLUB Y QUE!
ive hand an engine with the tab on the side
but ran with the mark on 12oclock ive seen some engine have tab on 12oclock right behind the water pump |
PHP Code:
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug waltshow.com/Chevy |
#8 | |
C10 CLUB Y QUE!
cause the engine ran really good like that could never get timed right i just gave it to my brother and he just timed it by ear RUNS GREAT still to this day if i wanted to really fix that first i would try to get engine numbers find out what yrs it is and what it came out of ! get more info on the engine |
#9 | |
C10 CLUB Y QUE!
in the front right under the heads or in the back driver side might need to get a flash light for that one
Senior Enthusiast
To locate the timing groove in the balancer, just slide under the truck with the engine off and look around the entire balancer, even if you have to bump the engine over. Once it is located, if everything is orange, a black sharpie will highlight the line. If everything is black or cruddy, a white, yellow, or silver crayon can help find the groove when using the timing light. If you still can't find the groove on the balancer with the timing light, it's likely be the distributor is installed 180 degrees out.
It's also possible to have a mismatch of parts on an engine with an unknown history. The factory spot welded timing tabs are not always in the same position on the cover. Depending on what was correct for that engine, the aftermarket bolt-on tabs may or may not accurately identify the correct setting. If this turns out to be the case, timing by ear is closer to accurate than using a light with incompatible parts. If there's any doubt the best solution would be to pull the plugs, find top dead center, and add a timing tape to the balancer in the correct relationship to the timing tab on the cover.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#13 |
Yes- not really too concerned about it, it was put back together pretty much stock and not planning on running down the track.
#14 |
![]() Join Date: Oct 2009
Your harmonic balancer may have spun on it's rubber core. This happened to mine. When I had #1 at TDC, the mark was about 90 degrees away. At the time, I had no idea that the outer ring of the HB with the timing mark could actually spin on it's hub due to the rubber going bad with age and either cracking or letting loose where it connects to the hub/outer balancer.
#15 | |
#16 |
#17 |
C10 CLUB Y QUE!
good you found them
#18 |
Mine did run once I ignored the timing mark and just found TDC and set the distributor to #1. I would not run using the timing mark, it was spun way too far from real TDC. I ended up replacing my HB with a rebuilt one from Damper Doctor.
#19 | |
#16876
#20 | |
fan of "Butters" Stotch
Its one thing if you are tuning high $$ race motor, high comperssion, or looking for hp numbers on the dyno but if you want to get that old, simple, low $$, just drive it around trusty SBC running good, forget the light. And yes, I will know I will get a little flack for saying it ![]()
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
#21 |
That's normally how I time my VW bug.
#22 |
and a few others
Don't mean to hijack the thread, but older VW's are supposed to be timed with a trouble light (not a timing light) with the engine not running. I was a mechanic at a VW dealership in the late 60's (yup, I'm an old fart)
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#23 |
That is right. I think in the manual it is referred as static timing. This will get you started at TDC.
Ed |
#24 |
Senior Car Nut
![]() Join Date: Jan 2008
edszuk, does your damper look like the V-8 one pictured above or is the pulley made right on the damper? reason I ask is that the manual for our trucks shows the 6 cyl timing mark to be just a small v-notch on the rim of the pulley. But your engine is 10 years newer so might be different.
My first thought, as mentioned earlier by steveb64, was that the damper has spun, which happens, especially if the engine ever backfired hard. As you know, fuel and electrical issues can often mimic each other and you can't easily chase down both at the same time. To me it sounds like a carb problem but until the timing thing is resolved you won't know for sure. If you have the type with the notch in the pulley, I can copy the picture from the manual and post it, just for your reference.
Larry |
#25 |
I know what you mean, but as far as I know they weren't flush from the factory.
Thread Tools | |
Display Modes | |
