Old 04-01-2010, 02:13 PM   #1
steinepstein
Widest front tire with no mods - 315?
I recall reading a thread where the discussion pertained to the widest tire on the front, does anyone recall the link or know how wide you can go on the front. I was sure someone had a 315 on the front with no mods.
Thanks,
JE
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216
steinepstein is offline   Reply With Quote
Old 04-01-2010, 02:37 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Widest front tire with no mods - 315?
JE... it's really going to depend on the wheel and it's specific BS. Do you have any additional info?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-01-2010, 02:43 PM   #3
steinepstein
I guess I was looking at it the other way because I need new wheels and tires so I was going to find the widest wheel I could fit under there and of course have the correct backspacing.
But oh yea, I see your point...I want them inside the wheel well...I don't want any rubbing issues because of cornering, braking, or lowering.....
Thanks!
Jon
Old 04-01-2010, 02:46 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I do see where you are coming from as well, I guess I looked at it from the point of... if I wanted to mount any tire up front without modification, then I would be able to afford a one-off custom wheel.
The dia. of the wheel will also hinder the size of tire you are able to choose from too.
I'm just curious what all you have planned...
-Nate
Old 04-01-2010, 02:52 PM   #5
steinepstein
I'd like the truck to handle as well as possible without major mods and I know the wider the tires the better it will handle, especially since I will be placing a wide tire in the back. If you go to wide in the back and skinnier in the front, the truck will push through a turn....at least at a basic tuning level.
JE
Thread Tools
Display Modes
